dyno numbers.
dyno numbers.
Postby 9312v » Mon Apr 23, 2012 2:14 pm
well got the truck on the dyno's at school and i put down on my best pull 225hp and 737 tq
but a good friend posed a reasonable question. how accurate are these numbers with a non lock up torque converter? i pulled in 3rd gear
9312v
Re: dyno numbers.
Postby JQmile » Tue Apr 24, 2012 9:06 pm
Torque sounds off. Should be 2:1 at the most.
JQmile
Re: dyno numbers.
Postby Tacoclaw » Wed Apr 25, 2012 6:47 am
Isn't that what a torque converter does? It trades available engine rpm for more torque (and heat)?
I can't look it up here(at work), but there was some explaination on a companies site about how the shape of the blades in a torque are actually able to increase the amount of torque provided. It's something about how it moves the fluid around.
Re: dyno numbers.
Postby Deathrod » Wed Apr 25, 2012 7:05 am
thats accurate of the power that makes it to the ground.....but like JQ said those numbers sound a little off in the ratio of hp to tq.
Deathrod
Re: dyno numbers.
Postby JQmile » Wed Apr 25, 2012 6:57 pm
What kind of dyno? Mustang?
JQmile
