Tacoclaw wrote:Well, Pete, I took your last comment to heart and decided to scrap the whole air to water setup.
With the new thread title change, I'm announcing that I've found a factory-style aftercooler and I'll be using it to run as my sole heat exchanger. After seeing all the boost leaks I'm not going to even bother trying to fix them all. My setup will now consist of a normal crossover going straight to the 'cooler.
Now then, I'm going to be asking this all over the place, so I'll start here. I've got the D-tech 62/65/12 turbo with the 3rdgen outlet on the compressor. This is obviously not the best for my setup, so I was wondering if anyone had any experience on whether a compressor housing off a normal 62mm S300 would fit on it.
