"Let me Google that for you"
Tacoclaw wrote:With the new thread title change, I'm announcing that I've found a factory-style aftercooler and I'll be using it to run as my sole heat exchanger. After seeing all the boost leaks I'm not going to even bother trying to fix them all. My setup will now consist of a normal crossover going straight to the 'cooler.
Tacoclaw wrote:Air to air is for quitters.
I'm getting a factory/industrial-style water after cooler and using my AC condensor setup to cool it. If I don't get rid of my shiny 'cooler I may look into using it between stages, using engine coolant, but that'll have to be one long winter to make me want to go through this again.
Tacoclaw wrote:Yeah, or that. Fine then, either a long winter or a short afternoon.
Shouldn't you be working?
Tacoclaw wrote:Shit, I need to get the thing actually huffing before I worry about upgrades for it.
By the way, the drive you took last night was with the boost set at 30psi. I didn't think to crank it up for you.
