A/C Condenser Tranny Cooler (Pictures)
Postby Begle1 » Wed Sep 26, 2007 8:12 pm
Drilled out; pretty good being done on a tailgate with a hand drill, if I say so myself... I used 3/8 MPT to 1/2 hose barbs, so I needed a 3/8 MPT tap which requires a 37/64's bit. Since I couldn't find a 37/64's bit, I used a 9/16's inch bit (which Ace charged a ridiculous amount of money for, I might add) and a lot of torque on the tap.
Tapped. Works best if you hold the cooler like a guitar, so you're pushing into your lap with the tap. And if you have the tap stuck into a 1/2 inch drive ratchet.
Barbs installed. Was afraid to use T-tape, so I used some blue Loctite stuff that supposedly doubled as liquid teflon. Hasn't leaked yet.
Here you can see how much larger the A/C condenser is than the stock transmission cooler.
I tapped into the ATF flow as it came out of the canister on the engine block. I cut the stock metal line (which might prove to be a mistake if I ever need to reuse it) and put a compression fitting with a hose barb on the stub.
The fluid comes out of the canister, and into a hose that I ran along the passenger side fender.
And then the hose enters into the barb that is on the A/C condenser.
And then a hose leaves the condenser and runs along the top of the radiator to reach the stock tranny cooler.
And then it enters into the stock tranny cooler, and then the ATF follows the stock return path from there. (I swapped the direction of flow through the stock cooler, so that I could get a larger radius on the line that drops down from the top of the radiator).
A dollar to anybody that spots anything I screwed up on is going to explode in a few miles. (Or who can tell me why my camera keeps acting like it's been smeared with KY.)
Postby wannadiesel » Thu Sep 27, 2007 5:09 pm
Well, if you weren't participating in the porn shoots the camera would stay clean. :roll:
Is that one of the A/C lines being reused as a trans line? Not sure I like that idea but I can't say why it wouldn't work.
I won't beat you up about the heater hose since you already got that figured out. :wink:
Best dyno: 408/844
wannadiesel
diesel guru
Postby Begle1 » Thu Sep 27, 2007 5:25 pm
That's a stock tranny cooler line on the driver's side.
You can't tell that's heater line from those shots, can you?
Now I got purdy red stuff. :oops:
Postby wannadiesel » Fri Sep 28, 2007 3:18 pm
Heater hose has a "puffy" look to the braiding. Most oil hose looks "tighter".
Best dyno: 408/844
wannadiesel
diesel guru
Users browsing this forum: No registered users and 72 guests
