lectro_static wrote:I just talked to a guy at Oregon Fuel Injection you are correct Mark the pump I was asking about is for an inline. They do carry the 3936320 pump and it sells for LESS then $65, he looked around a bit and found a pump that looks just like those two but is set at 12psi its a delphi #HFP701 and sells for $83.56. Does anyone know what the 3936320 is set at?
Mark would you share the url of where you got the fuel pump info at I think that could be very useful.
With the lift-pump, running PDR "190" injectors with the typically tweaked injection pump, I'm seeing . ..
- Approximately 12psig while free-revving the engine to 2500rpm.
- Approximately 9psig at idle.
- Approximately 7psig under WOT.
PToombs wrote:With my 3936320 I have 15-16 at idle and from 11 to 14 psi at wot (depending on temps) with my 370's and a maxed pump.
