I'm asking about the hard line that exits the block, where the turbo drain tube connects via a silicone hose. It's just under the oil filter, about 7-8 inches ahead of the passenger-side motor mount. How is that removed from the block? Is there an O-ring seal and it just pops out with some wriggling? Mine's covered with a bunch of built-up crud, so even if I could get around everything I couldn't really risk moving it around too much.
TIA for the replies, I'm finally to the oil feed and drain lines on these damn twins. It sucks to be staring at something that simple just laughing at you from it's little hole back there.
