Possible problem?
Possible problem?
Postby JustinRhodes » Thu Nov 03, 2011 5:33 pm
If i am WOT and i let out too quickly the truck will run rough, and sometimes die requiring me to crack the injector lines and bleed it then it will start back up. I never had this problem until i upgraded my turbo. Is there something i can do to correct this?
JustinRhodes
Re: Possible problem?
Postby Richie O » Thu Nov 03, 2011 6:10 pm
Let out slower. Common problem with high boost.
Postby JustinRhodes » Thu Nov 03, 2011 6:18 pm
Richie O wrote:Let out slower. Common problem with high boost.
Ok, wasnt sure if this was able to be fixed or not.
thanks
JustinRhodes
Postby Richie O » Thu Nov 03, 2011 6:21 pm
Most of the time its guys with twins that have that problem. I never have with any of my 3 and I have one around 48 psi of boost with no issues. I have a S300G a 62/71/14 HTT and a 60mm GDS H1C. I always jump off the fuel hard too. 8)
Postby JustinRhodes » Thu Nov 03, 2011 6:32 pm
Richie O wrote:Most of the time its guys with twins that have that problem. I never have with any of my 3 and I have one around 48 psi of boost with no issues. I have a S300G a 62/71/14 HTT and a 60mm GDS H1C. I always jump off the fuel hard too. 8)
mine is only at 45 psi. id say i have high drive pressure though too so i would guess it has something to do with that aswell.
JustinRhodes
Postby Tacoclaw » Thu Nov 03, 2011 6:59 pm
My truck never did this before, even pushing right up to 45psi with the single. Now I'm at 50psi with twins and if I let out too fast it'll die.
Justin, we've got a leg up on these auto guys. If it dies, just drop it in 5th and let it turn itself over as you roll. I've done it about 4 times now, it'll restart after a few seconds. 8)
Postby JustinRhodes » Thu Nov 03, 2011 8:29 pm
Tacoclaw wrote:My truck never did this before, even pushing right up to 45psi with the single. Now I'm at 50psi with twins and if I let out too fast it'll die.
:lol: if it starts to run rough for me i just floor mat it and it will come back to life but if you let off the pedal too quickly theres no saving it. ill have to try to remember to throw it in 5th next time i kill it, sure beats cracking a few injector lines. i dont mind so much about cracking the injector lines but going from the whatever egt i was at to it shutting down without letting that turbo cool down is what i hate.
JustinRhodes
Postby collegekid » Thu Nov 03, 2011 8:56 pm
what causes this, whats the solution
collegekid
Postby JustinRhodes » Thu Nov 03, 2011 9:02 pm
collegekid wrote:what causes this, whats the solution
too high of boost pressure and letting off the pedal slower :lol:
JustinRhodes
Postby ahale2772 » Fri Nov 04, 2011 3:50 am
aka lots of air forcing its way back up through the nozzle
Postby Douglas » Fri Nov 04, 2011 6:18 am
ahale2772 wrote:aka lots of air forcing its way back up through the nozzle
So it would seem that a clean, pop-pressure-set injector would not suffer this issue. Not likely that I'll ever have this issue though...way too far down the performance scale.
cheers,
Douglas
1991 D250, 727 and 16cm H1C.
Douglas
Postby Tacoclaw » Fri Nov 04, 2011 6:34 am
It will also get worse with bigger injectors. There's that much more surface area that the air can come back into.
Postby collegekid » Fri Nov 04, 2011 12:46 pm
And theres no injector or tip that can prevent this from happening?
collegekid
Postby AHineman » Sat Nov 05, 2011 3:47 pm
Douglas wrote:So it would seem that a clean, pop-pressure-set injector would not suffer this issue.
Douglas
They still do.
Postby 9453 » Sun Nov 06, 2011 3:11 pm
Wow you mean that there's enough back pressure to open the injector and push air into the injector seams impossible please explain kinda confused
9453
