Front Tranny Cooler
Front Tranny Cooler
Postby Mike T. » Fri Oct 05, 2007 4:59 pm
Have any of you put a larger tranny cooler up front and mounted it to the AC fins? I'd like to put a bigger one up front but everything is so tight. I'm also wondering if there would be an issues like additional heat. Any advice appreciated.
Thanks
Mike
93 w350 ext. cab,auto,354s,4"exh., smokey mt.,bhaf,htb2 62/65/12,CoolerTubz, ddp 55lpm inj.,Timed 1/8,Valet Switch,Piston LP,mild pump,3200 spring,ddp pin,Goerend TC,25k gvw trans cooler, deep pan,gauges,egt is pre.
Mike T.
Postby Begle1 » Fri Oct 05, 2007 6:21 pm
I just turned my A/C condenser into a tranny cooler. But that's because The Incubator doesn't have air conditioning.
http://1stgen.org/viewtopic.php?t=1258
Postby Mike T. » Fri Oct 05, 2007 6:40 pm
Althougt I'm sure it makes an excellant cooler I'm not ready to give up my AC.
Mike T.
Postby moab4x4 » Sun Oct 14, 2007 2:45 am
IMHO Being in AZ with the heat there, I would mount a fan cooled aux cooler under the bed. I have heard of but not seen dealer optional coolers mounted under the bed. There are some nice thermostatically switched units out there that would work.
I would not want to add more stuff the the front of the truck. The air already has to go through the AC and intercooler before getting to the radiator. In slow traffic, things might get warmer that I want. More than once I have had to turn off the AC on other vehicles to reduce overheating when i lived in PHX when I really would have liked to keep in on. :)
92 W350 LE Getrag, 3.54, 4"/2" lift,
HTT Stage II, POD's, 4", PDR cam, KDP, 3200 GSK, Pin ground, Keyed Valet
Pyro, Boost in Message Center, Isspro tach, Damplifier-ed entire cab! Dual Batts, Keyless Entry, LED's in dash
moab4x4
Postby Mike T. » Sun Oct 14, 2007 8:17 am
Moab 4x4
I have a B&M with a fan under the bed now. There are two sizes of the B&M coolers and I got the smaller of the two. I think it's rated at 15,000GVW not sure. In hind sight I should bought the bigger one.. Ya your right it's hot enough up front. I've decided to put a bigger one under the bed. I hate it when I have to do things over 2 or 3 times before I get it right.
Thanks
Mike
Mike T.
under bed coolers
Postby 93 dually » Fri Nov 09, 2007 1:12 am
ive got the big b&m cooler its great best thing i did trans temp stays cool even out in nevada were it gets 115 in the summer and hotter under the bed is the way to go
1993 d 350 htt turbo 5in stacks high flow intake .butchered fuel pin
93 dually
Postby Mike T. » Fri Nov 09, 2007 5:07 pm
The B&M are made well but I'm upgrading to a derale cooler w/fan rated at 25,000 gvw.
Mike
Mike T.
Users browsing this forum: No registered users and 84 guests
