90 motor into 92 truck
Postby jbaker » Fri May 31, 2013 4:53 am
what issues will I find putting a 90 cummins from a 2wd auto into a 92 4x4 auto truck that had a melted piston
93' w350 extended cab drw getrag, pump turned up and twisted, skirted flatbed
93 w350 extended cab drw auto, flatbed
jbaker
Re: 90 motor into 92 truck
Postby skilletky » Fri May 31, 2013 6:18 am
ksb wiring. and i think you will have to use the thermostat housing from the 93. may be more issues. ive never done it, just thinking of stuff that is differnet between the 2 engines.
skilletky
Postby CumminsPower59 » Fri May 31, 2013 7:05 am
Along with figuring something out if your going to keep it intercooled. The throttle brackets are different, and some modifications will need to be done to use the intercooled bracket with the non intercooled injection pump to injector lines.
