ps pump
ps pump
Postby DodgeFreak » Thu Nov 07, 2013 6:35 am
when you pull it off do you pull it from the vac pump or off the adapter??
Re: ps pump
Postby ellis93 » Thu Nov 07, 2013 7:44 am
I pull it from the bracket.
Re: ps pump
Postby DodgeFreak » Thu Nov 07, 2013 10:46 am
is there an oring or anything I need to worry about?? or pretty straight forward?
Re: ps pump
Postby ellis93 » Thu Nov 07, 2013 10:58 am
IIRC there's a seal there but its nothing that'll tear up easily. Take your time and it'll work out fine,pay attention to the way the index is between the two shaves drives. That's where most of the fight will be.
Re: ps pump
Postby DodgeFreak » Thu Nov 07, 2013 11:07 am
Thanks!
