Oil Pressure???
Oil Pressure???
Postby hassy21 » Sat Jul 05, 2008 1:30 pm
On start up my oil pressure is perfect and it is idled up where I want it but when it gets around 180-190 degrees and I come to a stop my oil pressure just drops and then when I get back on it th oild pressure rises again. Just wondering if there is something wrong with the sending unit with the gauge or what?
Thanks
hassy21
Postby PToombs » Sat Jul 05, 2008 3:49 pm
The sending units are known to be crappy. Plumb in a mechanical guage to check it, or just replace the sender.
Good Pumps
Postby Ace » Sat Jul 05, 2008 5:14 pm
The oil pumps on these engines are robust enough to keep good pressure at rpm even after the engine is badly worn.
Ace
Postby hassy21 » Sun Jul 06, 2008 1:02 am
Alrite guys thanks
hassy21
