cummins thermostat
cummins thermostat
Postby Remps » Sun Nov 15, 2009 7:09 pm
I recently installed a 180 F thermostat from cummins because the old one was stuck partially open, and now the truck will heat right up when idling around town,unless I put it in neutral and goose it once which kicks it open right away.And on the highway at higher speeds it barely comes off the cold mark.I know one of the two jiggle pins are aligned with the groove in the thermostat housing. Any ideas?
Postby Richie O » Sun Nov 15, 2009 7:34 pm
Heard of plenty of horror stories about junk thermostats. :roll: I sur will not replace mine til they fail like yours did.
Postby Firstgenfanatic » Sun Nov 15, 2009 7:53 pm
I just replaced my Thermostat with a Cummins direct replacement. My thermostat always seemed to be sitting around the high side all the time (even when the truck was empty and the outside temp was below 50 degrees). I figured the thermostat was worn out and decided to replace it. The difference was huge! The temp needle now sits at the lower side of the gauge when driving with the same previous conditions. The highest I have seen the needle go is half-way on the gauge. Definitely worth buying the Cummins thermostat. The auto part stores sell some pretty low-quality ones.........at least from what I hear/read about.
*1993 Dodge Ram W250 club cab*, mild performance built A518, Hughes Converter, turned-up VE w/timing bump, tow package, 16x7 Alcoa wheels, M&H "M5" fuel pin, 366 gov spring, 4" exhaust, 16cm turbine housing, cold air intake, Isspro pyro/trans/tach/boost, KDP secured
Firstgenfanatic
Postby Remps » Sun Nov 15, 2009 8:50 pm
Well I did buy the replacement thermostat from Cummins.Wasn't cheap either.(70 bucks Can.)It lso looked different from the three jiggle pin one that I pulled out.I have another old one (also three pin) that I may try.Under 1600 rpm this new one runs too hot,and above 2200 rpm it runs too cold.Had to cardboard half the rad so I could get a bit of heat on the highway.
Postby Moebiusgold » Mon Nov 16, 2009 1:36 am
Make sure that it is not in backwards. When I boughyt my truck the PO said he replaced the Thermostat. At idle it would run hot. Going down the road it was way cold. I bought a new Thermostat and when I put it in I saw that the PO had put it in backwards. The temperature sensing element was towards the rad. These things must have one hell of a water pump because evidently at higher RPM the water pressure must have been forcing the Tstat open!
92 W350 DRW
Moebiusgold
Postby dpuckett » Mon Nov 16, 2009 8:31 am
I've had decent luck with the $12 t-stats from the local NAPA. I tried it in Rumblefish's truck, and it sweeps a little, but at least it closes.
I will agree about the Cummins t-stats being pricey. ANd the ones I've installed still did the needle sweep thing.
Dan
Postby SNOOT » Mon Nov 16, 2009 8:39 am
Check out this link.. I know its a 3rd gen but they talk of manufactures so it should help a little..
http://www.nwbombers.com/forums/index.p ... =42099&hl=
1993 W350
SNOOT
Postby cougar » Mon Nov 16, 2009 9:51 am
Depends on what you need too. I could live with a warmer engine considering this morning it is -14°.
01 2500 "the work truck".
cougar
Postby PToombs » Mon Nov 16, 2009 6:41 pm
Wow, already? :shock: I guess I better start getting ready for it. :cry:
Winter has hit here also...
Postby MMeier » Mon Nov 16, 2009 11:01 pm
.... down in the mid 30's (F) the past 2 nights ! BBBRRRRR!!!
'93 W250CC, 5 speed, 3.54's, pump tweaks, NV4500 conversion, straight piped, 33's. Also, have '03 3500 QC 4WD dually, 551HP/ 1008 TQ @ MATS '07
MMeier
Postby PToombs » Tue Nov 17, 2009 6:30 pm
It's been 30 here at night, 28 last thursday. Supposed to be low 20's tonight. Wonder if I should plug the truck in? Naahhhhh, neighbor likes the rattle and white smoke! :lol:
Postby Richie O » Tue Nov 17, 2009 6:37 pm
PToombs wrote:It's been 30 here at night, 28 last thursday. Supposed to be low 20's tonight. Wonder if I should plug the truck in? Naahhhhh, neighbor likes the rattle and white smoke! :lol:
I was down to the parents house one night. Truck was cold ( I live next door) so I left it running. She was pretty smokey, it was after 9 pm. My aunt called my parents. " What is running in your yard? Its smoking us out of the house." O well. I guess Im on the s list now. :D
Postby cougar » Sat Nov 21, 2009 9:16 am
Is there a good 190° thermostat out there?
cougar
Postby Remps » Thu Dec 10, 2009 9:14 pm
Yep, it sure helps to put them in the right way! :roll: :lol: :lol: Works great now that I flipped it around. :shock:
Postby PToombs » Fri Dec 11, 2009 7:15 pm
Glad it was something simple. ;)
See! You can fix stupid! :lol:
