by flyinredneck » Fri Jul 15, 2011 10:10 am
when you you drilled and tapped you egt probe did you do it with the engine running or just suck the shavings out?
1992 w250 stock straight pipe with pump a lil tweaked denny t stage 2 fuel pin fuel screw at 3 turns
