ahale2772 wrote:do you have any easy way of checking the case pressure? (access to a lathe?)
that could be a big indication of whats wrong
Tacoclaw wrote:I figure to gut and tap your FSS to hook a gauge to.
Tacoclaw wrote:http://www.1stgen.org/viewtopic.php?f=1&t=7966&start=0
Tacoclaw wrote:It's created by the vane pump and the restriction built into the return line. No way to adjust it AFAIK, it's just a way to tell if something's wrong.
Bad vane pump or something like that.
oldestof11 wrote:The vane pump is the last thing you take out when disassembling.
oldestof11 wrote:Not hard. Just tedious.
JustinRhodes wrote:Tacoclaw wrote:http://www.1stgen.org/viewtopic.php?f=1&t=7966&start=0
Thanks.
How would one go about adjusting case pressure if its possible?
