need ideas of whats wrong with pump.
Re: need ideas of whats wrong with pump.
Postby JustinRhodes » Tue Dec 06, 2011 10:25 pm
Any other ideas anyone?
JustinRhodes
Postby ahale2772 » Wed Dec 07, 2011 4:55 am
do you have any easy way of checking the case pressure? (access to a lathe?)
that could be a big indication of whats wrong
Postby JustinRhodes » Wed Dec 07, 2011 5:55 pm
ahale2772 wrote:do you have any easy way of checking the case pressure? (access to a lathe?)
Uhm, what is the easiest/best way to check case pressure? What will i need access to a lathe for, but yes i do.
Fill me in on what your thinking, Id love to get this figured out before i swap it out :lol:
JustinRhodes
Postby Tacoclaw » Wed Dec 07, 2011 5:59 pm
I figure to gut and tap your FSS to hook a gauge to.
Postby JustinRhodes » Wed Dec 07, 2011 6:19 pm
Tacoclaw wrote:I figure to gut and tap your FSS to hook a gauge to.
What kind of numbers should the pump be pushing? Would an air pressure gauge be fine just to test it once?
JustinRhodes
Postby Tacoclaw » Wed Dec 07, 2011 6:29 pm
Postby JustinRhodes » Wed Dec 07, 2011 6:49 pm
Tacoclaw wrote:http://www.1stgen.org/viewtopic.php?f=1&t=7966&start=0
Thanks.
How would one go about adjusting case pressure if its possible?
JustinRhodes
Postby Tacoclaw » Wed Dec 07, 2011 6:58 pm
It's created by the vane pump and the restriction built into the return line. No way to adjust it AFAIK, it's just a way to tell if something's wrong.
Bad vane pump or something like that.
Postby JustinRhodes » Wed Dec 07, 2011 7:06 pm
Tacoclaw wrote:It's created by the vane pump and the restriction built into the return line. No way to adjust it AFAIK, it's just a way to tell if something's wrong.
I have my old pump for parts if needed. The vane pump im going to guess is hard to get too, how hard would it be to replace the lever the fuel screw pushes on?
JustinRhodes
Postby oldestof11 » Wed Dec 07, 2011 7:19 pm
The vane pump is the last thing you take out when disassembling.
Postby Tacoclaw » Wed Dec 07, 2011 7:22 pm
I'd pull the fulcrum out of that pump and put it in your old one.
Postby JustinRhodes » Wed Dec 07, 2011 7:22 pm
oldestof11 wrote:The vane pump is the last thing you take out when disassembling.
:shock: figures. Any idears how hard it would be to take off the lever the fuel screw pushes against and change it?
JustinRhodes
Postby oldestof11 » Wed Dec 07, 2011 7:42 pm
Not hard. Just tedious.
Postby JustinRhodes » Wed Dec 07, 2011 7:49 pm
oldestof11 wrote:Not hard. Just tedious.
I cant remember exactly what it looks like underneath the pump top but hopefully i can get it figured out
JustinRhodes
Postby ahale2772 » Thu Dec 08, 2011 5:10 am
Thanks.
i see 90-150 in nortmal driving.
if you had any kind of inlet line restriction, you might notice weird pressures, i suspect you are getting just enough fuel to maintain idle, and not enough to keep pressure to the plunger at high rpm.
feel free to send me your shut down solinoid and I'll make you one on the lathe...
