Adding 2 stroke oil to fuel???
Re: Adding 2 stroke oil to fuel???
Postby PToombs » Mon Nov 25, 2013 6:50 pm
Dunes, that's not exactly correct! Off road fuel saves you several cents on a gallon in taxes you aren't paying! :mrgreen:
Postby AHineman » Mon Nov 25, 2013 7:18 pm
Til you get caught and butt raped by the DOT.
Postby 1992gen1_fan » Mon Nov 25, 2013 8:50 pm
I think the fine on that is like $10k, it would take about me more than 20 years to make that up in money saved in no tax fuel.. I'll never run red fuel in my truck lol
1992gen1_fan
Postby PToombs » Tue Nov 26, 2013 7:21 pm
Pretty sure you're right on the fine, and that's the 1st offense. It goes up from there. I have done it in the past once in a while, but not anymore. The DOT is all over, more lately because the state thinks it needs the money. Plus my '92 I run to Indiana and Iowa, out there they check your truck when it's in a parking lot sometimes.
Postby RCCUMMINS89 » Tue Nov 26, 2013 8:32 pm
I've never seen or heard of anyone getting checked out here...........but just plain not worth it.
Postby ellis93 » Tue Nov 26, 2013 8:50 pm
RCCUMMINS89 wrote:I've never seen or heard of anyone getting checked out here...........but just plain not worth it.
Not to mention,it's some of the filthiest diesel you can buy.
I use to run it a lot till I started paying attention to the fuel filters on my tractors. That stuff....around here,maybe y'all have better stuff....is some nasty stuff. Builds some kinda gross algae in the sediment bowls and my God at the rust and trash I've ran across out of the tanks it's stored in. I don't think the tanks are as well kept as the on road stuff.....again around here.
Postby RCCUMMINS89 » Tue Nov 26, 2013 8:59 pm
Has anyone ever heard of 2 stroke gumming up the nozzles and building carbon deposits up?
I've heard that in the past that both atf and 2 stroke do such......
Postby 1STGENFARMBOY » Wed Nov 27, 2013 7:14 am
Not sure about that RC....but I think it has caused my truck to smoke a lot of bluish smoke and my batt gauge
is bouncing now that it got cold. :lol: :lol: :lol: :lol:
:mrgreen:
Postby RCCUMMINS89 » Wed Nov 27, 2013 8:01 am
Ya.... this whole winter thing (and I have no grid heaters) sucks........I'm about to put in 30x.001 injectors. Maybe then the fire department won't get called to our house when I fire it up. :lol: :lol: :lol:
So, for a little story.... The other day my dad filled up his truck and asked me "I have 2 gallons of 2 year old mixed gas, do you think I can add that to my tank"? I said, "shouldn't hurt anything, I'd add a little extra 2 stroke in it for good measure". So he adds it in.
No joke, I bet it added 50hp to his stock truck. He asked if I thought it has the 2 stroke or the gas. I told him that "Ya, I bet that gas wasn't that old". :lol:
Postby cmann250 » Wed Nov 27, 2013 8:37 am
Red fuel debates are some of the most epic ever :lol:
I just wish I could still buy diesel made to 1989 specs at 1989 prices.
Postby The_Head » Wed Nov 27, 2013 12:06 pm
I don't know how it is in your states, but I have NEVER had my tank dipped in either my personal vehicle or a commercial vehicle. I'm still not taking the risk though, cause you never know.
I haven't been doing the 2 stroke oil thing for a few years either. I just add whatever diesel additive is handy at the time. There's a few old junker first gens running around in my town and I would bet they don't add anything either, and they are still on the road.
The_Head
Postby 1STGENFARMBOY » Wed Nov 27, 2013 1:23 pm
I don't think you have to, but I don't think it hurts anything. I mean the more lube the better to a point.
Postby Tacoclaw » Wed Nov 27, 2013 1:46 pm
Back your timing off some for the winter, RC. My truck covered my whole house in smoke when I had it a tooth+maxed slots. I pulled it back to half slot and it barely smokes at all.
Postby 1992gen1_fan » Wed Nov 27, 2013 3:31 pm
I have noticed slightly more haze if I use 2 stroke oil alot, I'd say it could cause more than usual carbon buildup on the injectors if it makes the exhaust dirtier. I generally only add it every 2-3 fill ups when I think of it, sometimes less often.
1992gen1_fan
Postby JimmieD » Wed Nov 27, 2013 8:44 pm
I've been using the Wally World TC-3 or whatever it is 2 stroke oil for several years, VE pump 4BT. I noticed no increase in smoke with it. I doubt it causes deposits or gums things up because it's specifically formulated to be used in small engine carburetion systems that have REALLY small orifices and jets, and it's designed as well to be burned in the combustion chamber. Just because diesel uses compression to produce spark compared to a spark plug induced spark I can't see there being any major difference? That re-labeled Wally oil is made by a major mfgr. that's highly respected, can't remember who, is it Valvoline...?
1967 Dodge D-100 Town Wagon - CPL 858 4BT, HTT Stage II/H1C 16cm/56cm turbo, '93 CTD I/C, 32K spring, minor fuel tweaks, milled head, NV4500, 1 ton springs, '72 D-200 Frt. axle w/ Air Lift bags, 4.10 Dana 60HD, F/R swaybars, Tom Woods shaft.
'90 W-350 gasser...
JimmieD
