piston lift pump came apart
Re: piston lift pump came apart
Postby CumminsPower59 » Thu Jan 24, 2013 6:16 am
Depends, I will run one on my 91 eventually, and probably check it every time I swap fuel filters, which was every 10k...
Postby cmann250 » Thu Jan 24, 2013 6:24 am
I'm due for an oil change and fuel filter here in about 500 miles. I didn't know if they were a screen and they'd theoretically last forever or if there's filter media in there.
Postby CumminsPower59 » Thu Jan 24, 2013 6:55 am
I haven't opened one up, but here is a little story for you...
During my first deployment to Iraq in early 2003, several of out 5 ton trucks had 8.3 Cummins in them. The fuel filtration system was basically the same, except they had an in line prefilter almost exactly to what I posted earlier. The problem we had was that there was a modification kit for these trucks to use install a HUGE fuel filter and replace that little strainer, but most of the trucks didn't get them installed in time to push north into Iraq. Problems arose, lots of plugged up strainers because of the crappy fuel we had, and no new strainers to replace them. So, in a pinch, when one would plug up, we would pull it off real quick and blow through the outlet and clean it out as best we could so we could continue moving... Worked many times.
So, in therory, one could use one for quite a while if you could blow it out and get most of the trash out of it. I bought a pack of them, and didn't spend too much, I think they were a few bucks a piece...
Postby cmann250 » Thu Jan 24, 2013 7:07 am
Yea I looked around and they're stainless mesh inside. They range from about $6-15.
http://www.dieselmanor.com/fleetguard/FF5079.asp
Postby rockmike » Thu Jan 24, 2013 10:06 am
dunes450r wrote:
rockmike wrote:I have that lil valve screen doohicky in an old #@*^#* piston LP im replacing.
Pm me you address and I'll mail it to ya if you would like?
thanks
As you can see by my post count im new here,I got an email saying you pm's me.But I get a message that im not allowed to have pm's just yet??? I cant see pics on some post also.
But I do have that screen,and im more than happy to help ya out and mail it to ya but I got no addy...
rockmike
Postby dunes450r » Thu Jan 24, 2013 11:01 am
thanks
ok, i appreciate the help, but the screen isn't the problem, here's a link to the picture:
http://i759.photobucket.com/albums/xx23 ... 3f688d.jpg
some parts inside the pump actually came apart and got chewed up due to the pump being ran with broken pieces inside before i bought it
dunes450r
Postby RCCUMMINS89 » Thu Jan 24, 2013 11:11 am
The important part of this equation: How does the cylinder wall inside of the pump look? How does the piston (plunger) itself look on the side. If there are no visible scratches or gouges, you can probably replace the piston assembly and run it. If there are gouges or scratches...well, obviously it is not going to work well.
Mike is really helping out here... thanks Mike.
Postby rockmike » Thu Jan 24, 2013 12:04 pm
My pleasure! Ive noticed 1st gen cummins guys are alot like suszuki samurai guys...were a lil on the cheap ass side lol and will do anything to help a fellow inthusieast out!
rockmike
Postby CumminsPower59 » Thu Jan 24, 2013 4:41 pm
rockmike wrote:My pleasure! Ive noticed 1st gen cummins guys are alot like suszuki samurai guys...were a lil on the cheap ass side lol and will do anything to help a fellow inthusieast out!
That's right! I have a 88 tin top Sammy. The woman hates it but I love driving it! :mrgreen:
Postby bmoeller » Thu Jan 24, 2013 5:04 pm
You actually fit IN it, Ike? :lol: Doubt I would. :lol:
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby PToombs » Thu Jan 24, 2013 5:29 pm
That would be like Jaws driving in the Bond movie, lol!
Postby CumminsPower59 » Thu Jan 24, 2013 7:16 pm
Bryan, you would, somewhat comfortably too. I have had a friend of mine hitch a ride in it, back when it was my only means of transportation...and he liked it.
Postby dunes450r » Thu Jan 24, 2013 7:37 pm
mike: is the pump you have a low volume pump, or a high volume pump? the piston, and cylinder walls is the pump i have look good. i didn't think you could get a new piston assembly?
dunes450r
Postby rockmike » Fri Jan 25, 2013 10:17 am
dunes450r wrote:mike: is the pump you have a low volume pump, or a high volume pump? the piston, and cylinder walls is the pump i have look good. i didn't think you could get a new piston assembly?
My pump is the hfp702.delphi pump its low pressure,with a broken fuel inlet.Im in the process of replacing it right now with a true 12 psi cummins piston pump I bought from The HUngry Diesel.com
rockmike
Postby rockmike » Fri Jan 25, 2013 10:20 am
Hey Dunes I still cant recieve pm's here...
IM a member over on the http://www.dieseltruckresource.com/dev/ ... y.php?f=93 site I use the same screen name.You could send me a pm with your addy over there then I could get the screen mailed out to ya.
rockmike
