replacing head,do I need the head studs?
Re: replacing head,do I need the head studs?
Postby RCCUMMINS89 » Wed Feb 06, 2013 10:26 am
The stock bolts aren't a 12 point.... I thought I used a 14????? been a while and don't remember now.
Postby rockmike » Wed Feb 06, 2013 10:45 am
Ya there a hex head,it just seemed any size I tried didnt fit the bolt head very tight? I wondered if they where kinda odd ball sized that would require a certain size but 12 point to fit right?
Pretty sure the ARP's are 14mm 12 point...
93 d350 extra cab 5 speed dually.
Mods: hx35,rotated fuel pin,bosch 190 inj.,BHAF with smooth intake tube,3200 rpm spring,M&H dynamic timing spacer,isspro EGT and boost gauge,Auto meter tach, fuel press. gauge.Diamond eye 4" exhaust,Sno Stage 2 W/M kit.
Real trucks dont use spark plugs!
rockmike
Postby RCCUMMINS89 » Wed Feb 06, 2013 10:55 am
Ya... maybe they were a 15? The more I think about it I used a loose fitting SAE to get them out.
Reason I brought up the 12 point is, I was hoping maybe you had a 12 point of some sort already in there...which would of meant you had aftermarket studs or bolts already how cool would that of been?
Postby oldestof11 » Wed Feb 06, 2013 4:38 pm
I am 90% sure it is a 14mm. The other 10% is 15mm.
Best bet is to use a 6 point. Won't round the heads as easily. The only reason why I like 12pts are for square nuts and 12pt nuts.
Postby PToombs » Wed Feb 06, 2013 6:21 pm
I can't remember what size the headbolts are either. :oops: I kinda think I used a 3/4 or 18mm on them, they were bigger than 15mm......
Mike, on the pushrods, put a small dab of grease on the end. If it's in the socket on the tappet when you pull up it will have a little resistance from the suction. If you miss it will come right up. ;)
Postby turboram » Wed Feb 06, 2013 6:30 pm
18mm it the head bolt hex size
turboram
Postby rockmike » Thu Feb 07, 2013 11:03 am
PToombs wrote:I can't remember what size the headbolts are either. :oops: I kinda think I used a 3/4 or 18mm on them, they were bigger than 15mm......
Good call, I would have just used some assembly lube on them,I'll put some of the staplex "sticky" red grease on them...just a lil dab.
Thanks!
rockmike
Postby rockmike » Thu Feb 07, 2013 11:06 am
turboram wrote:18mm it the head bolt hex size
There weird?? the 17mm end wrench dont fit the 11/16 end wrench ,if ya really force it will fit? I dont have an 18mm 12 point,seems the 6 point was sloppy.I found a 1/2" drive 12 point 11/16 socket that fit them nicely. 8)
Thanks again guys.
rockmike
Postby rockmike » Thu Feb 07, 2013 11:15 am
Just got to get that damn fuel return line loose,that fitting back there is tough to get to and its tight! Trying not to screw that up...But ya just get that fitting off there and take the head bolts out and remove the head and start cleaning :mrgreen: Ended up breaking one exhaust manifold bolt.
I think I would like to replace all them manifold bolts and the turbo mounting studs.
Do I need to get them through cummins or is there another source for them??
Thanks guys!
rockmike
Postby RCCUMMINS89 » Thu Feb 07, 2013 11:45 am
Probably be cheaper to just order some grade 8 studs to replace them.
Postby rockmike » Thu Feb 07, 2013 12:10 pm
Cummins NW in Yakima has the manifold bolts and turbo studs and nuts for $75.87
rockmike
Postby RCCUMMINS89 » Thu Feb 07, 2013 12:11 pm
That's ridiculous if you ask me.
Postby rockmike » Thu Feb 07, 2013 12:47 pm
RCCUMMINS89 wrote:That's ridiculous if you ask me.
I agree there just freaking bolts!lol I called around and found some stainless 8.8 allen head bolts with H.D washers and lock washers locally for a fraction of the cummins cost. 8)
Incase someone some day is searching this. I went with 10x1.50x70 mm for the manifold mounting bolts...went a lil longer for the extra washers.Sticking with some grade 8 studs and nuts for the turbo mounting flange,got to be able to tighten those with a wrench,its tight in there for a couple of them.10x1.50x30mm
My new head just showed up :mrgreen: damn that thing is HEAVY! UPS said 140lbs :|
rockmike
Postby rockmike » Thu Feb 07, 2013 1:03 pm
100_0586 by ffolted, on Flickr
100_0587 by ffolted, on Flickr
8)
This'll get her fixed right :cheese:
rockmike
Postby skilletky » Thu Feb 07, 2013 1:30 pm
are you gonna have it oringed?
skilletky
