89-91 tach versus 92-93 tach
Re: 89-91 tach versus 92-93 tach
Postby CumminsPower59 » Sun Jun 02, 2013 6:42 pm
My 91, non-ic truck has a notched dampner, but there is no tach pickup or plug anywhere...
Postby Mark Nixon » Sun Jun 02, 2013 7:49 pm
Yes, it needs the notches in the damper to work.
The notched damper was hit and miss in 1990 and 1991.
I 've seen notches in them for both years, but I can't say that the dampers weren't swapped to fix a bad one, or to make a tach work.
The 1990 and 1991s do have the factory supporting harness under the dash in a similar place to the 1992/3s.
I haven't thought to look at a 1989 to see if it also has the plug, so I cannot say one way or the other on it.
Postby Sidebottom » Mon Jun 10, 2013 7:19 pm
how much does the kit cost
Sidebottom
