what in the world is this growling I hear in my 92
Re: what in the world is this growling I hear in my 92
Postby skilletky » Sat Apr 20, 2013 5:15 am
You need a stethoscope.
skilletky
Postby cougar » Sat Apr 20, 2013 7:44 am
01 2500 "the work truck".
cougar
Postby TRACTJDS0428 » Sat Apr 20, 2013 5:20 pm
Is it running on all cylinders? Had a RoGator with a 5.9 break the cam at the last cylinder. Sounded about like you are saying till it made a big hole in the block but it still ran an drove. just down one hole. just a thought.
1993 Dodge W250, Cold Air, Borg Warner 60/68 turbo. 4" down pipe. 5x14 Injectors. Pump Mods. Airdogg II 165, Billet Fuel Tank Sump. ATS valve body, ATS converter, Pyro, Fuel pressure, Boost and Trany temp gauges. 72" T-Rex Products Long Bars. 285/75-16 Toyo Open Country M/T's. Western 9Ft MVP Ultra Mount V-Plow.
TRACTJDS0428
Postby hager » Sun Apr 21, 2013 6:20 am
Great I'll look at that .
hager
Postby hager » Tue Apr 23, 2013 7:12 am
I am working in Colorado now I'll be home by next Monday and then I'll diagnose problems thanks for all your guys help
hager
Postby 1990CTD » Tue Apr 23, 2013 11:37 am
If it sounds like its coming from the transmission or the back of the motor check the rear end. I had a 96 f250 7.3 that the rear end was low on grease and started chewing up the gears. The sound will travel through the driveshaft making you think its the tranny.
1990CTD
Postby hager » Tue Apr 23, 2013 4:56 pm
would I have to be moving to get that noise because I get this noise parked or moving
hager
Postby 1990CTD » Wed Apr 24, 2013 10:47 am
Well mine only did it moving so I guess it not that. But you could check into it.
1990CTD
Postby hager » Wed Apr 24, 2013 2:47 pm
Ok will do thanks
hager
Postby hager » Wed May 01, 2013 6:49 pm
well just to give you guys an update I do believe I found my problem it was number 6 cylinder spun main bearing the crankshaft looks pretty bad I'm going to have to pull it out have it machine .well as it is now I have the whole core support out my truck it looks pretty discouraging .what's the easiest way to remove a crankshaft? Sould I pull the engine or should I do it from the truck if so how would I?
hager
Postby dazedandconfused » Wed May 01, 2013 6:51 pm
Just pull the rest of the engine.
Postby Tacoclaw » Wed May 01, 2013 7:09 pm
Yup, I couldn't even get an oil pan gasket in while my engine was in the truck, I can just imagine how fun getting the crank out would be. :lol:
Postby hager » Wed May 01, 2013 7:17 pm
okay I'm pretty much ready to pull just a few things and I'll be pulling tomorrow
hager
Postby hager » Wed May 01, 2013 7:23 pm
ImageI above are some pictures just realized I haven't put any pictures up of my pickup I'm going to get some more up of my truck
hager
Postby dazedandconfused » Thu May 02, 2013 4:00 am
That's a sharp truck.
