1989 dodge w350 missing under load
Re: 1989 dodge w350 missing under load
Postby RCCUMMINS89 » Thu Jan 22, 2015 11:20 pm
So it started smoking white after the valve lash?
If it was smoking prior, and you just noticed it today after the valve lash........injectors or air. If it is not doing it an idle, I would suspect air. Other option is injection pump, but probably not, since it is new.
Postby manostihl » Fri Jan 23, 2015 8:38 am
RCCUMMINS89 wrote:So it started smoking white after the valve lash?
No it didnt just start smoking white after the valve lash it always has i just got confused about the color
manostihl
Postby manostihl » Fri Jan 23, 2015 3:19 pm
im pretty sure it needs injectors. The ol girl has some miles on her idk how much because the odometer hasnt worked in i dont know how long and has a little blowby. would there be any point to rebuilding and cleaning them ? because i cant find the 9mm injectors anywhere new and id like to stick with the 9mm setup.
manostihl
Postby manostihl » Fri Jan 23, 2015 4:06 pm
i just cracked all the injector lines and cylinders 1 and 4 made less of a difference but all the rest made a huge difference. think i should just try some sea foam in it?
manostihl
Postby RCCUMMINS89 » Fri Jan 23, 2015 4:11 pm
We can do a set of completely stock injectors? Original 9mm nozzles and everything.
Or a set of 5x12 VCO marine angle 9mm injectors as well.
Postby manostihl » Fri Jan 23, 2015 4:40 pm
RCCUMMINS89 wrote:We can do a set of completely stock injectors? Original 9mm nozzles and everything.
i thought that marine angle wasnt right for a street/towing engine? what is the cost?
manostihl
Postby RCCUMMINS89 » Fri Jan 23, 2015 4:59 pm
Marine angle is the same angle as you have now....
Let me get back to you on cost. It has been quite along time since we have sold the 9mm tips (not very common for folks to stay that route) and I need to check if costs have gone up. It may not be til Monday, but I WILL get back to you with pricing.
Postby manostihl » Fri Jan 23, 2015 5:09 pm
RCCUMMINS89 wrote:Marine angle is the same angle as you have now....
ok thanks let me know. why is it not common for people to stay with the 9mm tips? i just dont want to spent the extra money on adapters especially to downsize lol
manostihl
Postby manostihl » Fri Jan 23, 2015 5:20 pm
i also noticed it seems to be leaking compression by the injectors in between the injector body and the hold down nut. because when i cracked the injector lines and fuel was sitting on top it was bubbling there on at least 4 of the injectors
manostihl
Postby RCCUMMINS89 » Fri Jan 23, 2015 5:56 pm
Downsize? 9mm vs 7mm have nothing to do with flow.
But I put 9mm tips in my dad's truck. The advantage of the swap is to utilize a marine 370 injector. By far the best injector to put in a non i/c truck.
Postby manostihl » Fri Jan 23, 2015 6:18 pm
RCCUMMINS89 wrote:Downsize? 9mm vs 7mm have nothing to do with flow.
ahhh ic i would deff like to stick with what i got to stay on the cheaper side or go marine. just dont have a whole lot of cash right now because im in between jobs. but shes my primary steed so i need her up and running. even if i have to sell some things.
manostihl
Postby CumminsPower59 » Sat Jan 24, 2015 5:07 am
manostihl wrote: i just dont want to spent the extra money on adapters especially to downsize lol
Dude, the adapters aren't expensive. Pennies on the dollar. If you ever have to pull/replace the head, you'll see your 9mm head is cracked and most machine shops will convince you that its junk (most likely isnt). My point being, if you get 7mm injectors, you're money ahead if you have to swap heads down the road.
Postby manostihl » Sat Jan 24, 2015 9:40 am
They were at least an extra 40 bucks. I just want to use what i have if possible and keep it cheap. Like i said im in between jobs and i dont have a lot of money to spend. Actually none at all right now lol
manostihl
Postby RCCUMMINS89 » Sat Jan 24, 2015 9:49 am
The best idea might be just to get your current ones checked out.
Postby manostihl » Mon Jan 26, 2015 1:03 pm
RCCUMMINS89 wrote:The best idea might be just to get your current ones checked out.
i will. i just got all but one pulled . they all were pretty carboned up on the tips but i dont know. does anyone know how to tell if theyre stock injectors or not?
manostihl
