RCCUMMINS89 wrote:So it started smoking white after the valve lash?
If it was smoking prior, and you just noticed it today after the valve lash........injectors or air. If it is not doing it an idle, I would suspect air. Other option is injection pump, but probably not, since it is new.
i thought that marine angle wasnt right for a street/towing engine? what is the cost?RCCUMMINS89 wrote:We can do a set of completely stock injectors? Original 9mm nozzles and everything.
Or a set of 5x12 VCO marine angle 9mm injectors as well.
RCCUMMINS89 wrote:Marine angle is the same angle as you have now....
Let me get back to you on cost. It has been quite along time since we have sold the 9mm tips (not very common for folks to stay that route) and I need to check if costs have gone up. It may not be til Monday, but I WILL get back to you with pricing.
RCCUMMINS89 wrote:Downsize? 9mm vs 7mm have nothing to do with flow.
But I put 9mm tips in my dad's truck. The advantage of the swap is to utilize a marine 370 injector. By far the best injector to put in a non i/c truck.
manostihl wrote: i just dont want to spent the extra money on adapters especially to downsize lol
CumminsPower59 wrote:manostihl wrote: i just dont want to spent the extra money on adapters especially to downsize lol
Dude, the adapters aren't expensive. Pennies on the dollar. If you ever have to pull/replace the head, you'll see your 9mm head is cracked and most machine shops will convince you that its junk (most likely isnt). My point being, if you get 7mm injectors, you're money ahead if you have to swap heads down the road.
RCCUMMINS89 wrote:The best idea might be just to get your current ones checked out.
