chewin up shut off solenoids
Postby KRB64 » Sun Nov 30, 2008 5:55 am
Is there any possible damage to letting the truck idle while the ignition is off? I mean, there is no electrical usage while the alternator is not charging while the PCM is shut off correct? I'm talking about for a '92.
'92 W250 CC LE, auto, OD on shift, 3.54 limited; boost/PT pyro/tranny, oil temp, fuel press, tach; Bosch 190s, Ol' Smoky, 366 spring, full fuel, pull cable, 1/8" bump, synthetics, Borgeson, aFe, 16cm house, 4" pipe, AT cooler, ton shoes, ext reg...
KRB64
Postby TWorline » Sun Nov 30, 2008 6:22 am
None that I have encountered yet, and have noticed no issues while driving with the ignition off, well with exception of the steering wheel not wanting to turn!
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby KRB64 » Sun Nov 30, 2008 7:20 am
Yikes! :shock:
KRB64
Postby nkendall07 » Fri Jan 09, 2009 7:34 pm
Holly crap now I know that I am not he only one with this issue!!! I thought this was just my problem all the pump guys around here kept telling me the cam was chewong up causing the issue. Now my pump is at the shop being rebuilt again for this problem. Where were you guys at two days ago!!!!???!!!!!
93 drw x-cab 4x4 5x14 coaltrain massaged injectors, 4 inch exhaust, hx40 hybrid, wound up pump, home made cold air intake.
nkendall07
Postby RumbleFish » Sat Nov 21, 2009 7:36 pm
dammit. got to work today and my truck wouldnt shut off. i refuse to go with a cable, other than a temporary fix until my new solenoid shows up. and my pump isnt even close to maxed out. wtf....
anyway, heres a bump for the next time somebody needs the vw parts link.
Postby PToombs » Sat Nov 21, 2009 7:50 pm
3 other options, don't whomp on it, don't let off quick, or get bigger injectors. ;)
Postby Richie O » Sat Nov 21, 2009 7:58 pm
I hope my 93 is fine with my big sticks. The 89 worries me some. That truck is real close to runaway with stock sticks. :?
Postby PToombs » Sat Nov 21, 2009 8:03 pm
Big sticks are ok, the 89 will give you problems if you let off quick a lot. It's the backwash that kills the rubber tip. ;)
Postby Richie O » Sat Nov 21, 2009 8:04 pm
I know, I do that all the time too. :oops:
Postby RumbleFish » Sat Nov 21, 2009 8:25 pm
bigger injectors are on the to-do list. i think they just got moved up higher on the list after today. im leaning toward 190's. dont whomp on it? thats no fun!!
Postby PToombs » Sun Nov 22, 2009 6:20 pm
Jeff, 190's are smaller, but atomize better, that's why they make more power. They may not cure the chipping problem. The truck will run better and get better mileage though. ;)
Postby Swaggs » Sat Nov 28, 2009 3:54 pm
So I think I just ate up my first shut off solonoid. I am bummed. I have my pump turned up a bit, and I just put in a Denny T pin and was cruisin on the freeway, and when I got off the freeway it was idling high (1000 rpm) and wouldnt shut off.. So then on the way home, i was letting off the fuel and the rpm was kinda hangin. I got home and backed out my full fuel screw. I drove it again, and its still idling around 1000.. strange..
anyone have any ideas?
92 W250 CTD, Getrag, hx35, DiamondEye, Mostly Stock
89 Ramcharger 360/727
'92 W250 CTD, Lifted Sold
'96 2500 CTD Sold
Swaggs
Postby peobryant » Sat Nov 28, 2009 5:25 pm
Swaggs wrote:So I think I just ate up my first shut off solonoid. I am bummed. I have my pump turned up a bit, and I just put in a Denny T pin and was cruisin on the freeway, and when I got off the freeway it was idling high (1000 rpm) and wouldnt shut off.. So then on the way home, i was letting off the fuel and the rpm was kinda hangin. I got home and backed out my full fuel screw. I drove it again, and its still idling around 1000.. strange..
It's the turned up pump that's doing it. It seems to be more of a problem on intercooled trucks, because we have tiny factory injectors. You can keep getting more solenoids while you wait to get bigger injectors, but they'll get blown too, or you can just keep using the lever on the side of the pump to shut her off until you get the injectors. I'd just use the lever, I'm cheap. :lol:
Postby Ace » Sat Nov 28, 2009 6:31 pm
I've been running the pull cable over two years now. Never did lose a solenoid from that issue, just took it out right along with installing the BD fuel cone. The way I look at it, just one less thing to worry about.
Ace
Postby Swaggs » Sat Nov 28, 2009 7:12 pm
Do you think that the idling high, and the rpms hanging a little is from the shut off plunger? or is it another problem?
'96 2500 CTD Sold
Swaggs
