Help! Name this knock. (Videos)
Postby Darren A » Fri Oct 23, 2009 9:34 pm
1STGENFARMBOY wrote:Trade holes with a diffrent injector, i definatly hear it in the first video, the idle sounds a little low to me, will it stop if you bump up the idle alittle.
It makes the knock thoughout any RPM, I was doing a burnout the other day and it was really noticeable off the governor.
Darren A
Postby dieselhotrodder » Sat Oct 24, 2009 8:30 am
get a laser temp gun and see how close of temp each exhaust port is. sounds like you have an injetor sprayin into the side of the cylinder no into the proper area causeing the pistion to ting... like a gasser with crappy fuel
dieselhotrodder
Postby Darren A » Sat Oct 24, 2009 3:38 pm
ahale2772 wrote:well if its definitly # six then there is your issue have u cracked any others to see if the #6 injector sprays as much as the others?
I have cracked all 6 and only get rid of the knock when i crack #6.
Darren A
Postby 1STGENFARMBOY » Sat Oct 24, 2009 5:17 pm
After reading all the posts I do agree with Mark Nixon its just like a gasser with a loose wrist pin or loose rod bearing when you change the firing (injector on a diesel or plug wire on a gas) it normaly goes away or gets considerably less . just my thought. :scratch: I heard the samething on a diesel 560 IH
Postby skilletky » Sat Oct 24, 2009 9:26 pm
x2 on the wrist pin. i have had 4 s60 driptroits and 2 isx's that have the same problem and in all cases it was the wrist pin. of course working for a trucking company who is trying to save every dollar says to let it go, then the truck comes in on a wrecker with the #6 rod sticking through the block. then all you can say is i told you so
skilletky
Postby Darren A » Sun Oct 25, 2009 1:46 pm
Ya i was also thinking the wrist pin. I'll have the head off in the spring so i'll take #6 out and take a look at it then. Maybe it'll give me an excuse to pull out the engine and get it balanced and blueprinted. :lol:
Darren A
Postby PToombs » Sun Oct 25, 2009 5:43 pm
Do your self a favor. Swap the #6 injector with another one to make sure it's the hole and not the injector.
I saw a Cat D4 once that knocked like a SOB and you'd swear the rods were coming out the side at any minute. Turns out the injectors were dirty from sitting or something, when we started to run it hard, within an hour it had cleaned up and ran like a dream.
Postby Darren A » Sun Oct 25, 2009 6:41 pm
Thanks for all the help guys, i've got many things to take a look at by the sounds of it.
Darren A
