full power fueling screw
Re: full power fueling screw
Postby BILTIT » Thu Jul 21, 2011 7:31 am
Idle screw is to be turned down until proper idle speed is attained, however many turns that takes.
Derek B.
BILTIT
Postby Remps » Thu Jul 21, 2011 11:27 am
Just turn the idle down so its lower than normal and bring it back up with the fuel screw. Don't forget to have a flat board ready.And remove intake tube from the turbo.
Postby cmann250 » Thu Jul 21, 2011 1:18 pm
As for getting the collar off, i put the fuel screw in a vise with wood shims to protect the threads and used a chisel to split the collar and pliers to pull it off. I used a file on the rough spots and carefully backed the nut off to straighten the threads. It'd be better to use a tap and die set... :roll:
Postby DieselLam » Sat Jul 30, 2011 11:55 pm
Did you guys just play it by ear or did you actually measure the rpm's
1993 D-250 straight pipe, PDR intake, Pump tweaked. KDP DDP fuel pin.
DieselLam
Postby oldestof11 » Sun Jul 31, 2011 11:31 am
Ear for me.
Postby cmann250 » Sun Jul 31, 2011 12:49 pm
^x2 It took me a few trial-and-errors since i have an auto. If the idle is too high, it'll go 15 mph just idling down the road and you have to ride the brakes to go any slower :oops:
Postby BILTIT » Sun Jul 31, 2011 3:49 pm
DieselLam wrote:Did you guys just play it by ear or did you actually measure the rpm's
Thats the reason i bought a tach.
Derek B.
BILTIT
Postby Hansen01 » Sun Jul 31, 2011 7:03 pm
jus play it by ear, and by how it feels, i didnt have a tach when i did all my tuning
Under construction...
Hansen01
Postby DieselLam » Tue Aug 02, 2011 7:59 pm
I got the idle down right but ever since I turned the power screw in it has been idling erratically. What should I do about that
DieselLam
Postby Hansen01 » Tue Aug 02, 2011 9:38 pm
what kind of irratically?
Hansen01
Postby DieselLam » Wed Aug 03, 2011 12:09 am
Sounds maybe like it may not be getting enough fuel toa injector.or 2 not a smooth idle . It isn't surging or hunting. It is not smoking but when increase throttle it runs perfect
DieselLam
Postby Hansen01 » Wed Aug 03, 2011 5:49 am
and it didnt do this before? when i did mine it kinda loped for a while, and then one day quit, theres still a little one, but not much
Hansen01
Postby cmann250 » Wed Aug 03, 2011 6:37 am
Could it be idling too low? If you bring the idle up, it smooths out. Mine idled so low that it shook the whole truck and almost stalled. It would sound rough and choppy, and as soon as i touched the gas pedal, it was normal again until i let it return to idle
Postby Hansen01 » Wed Aug 03, 2011 3:00 pm
could be, yes jus adjust the idle up and see what happens, im sure yul know when its to high or to low for your likes, the screw closest to the head if you didnt know, or you could try adjusting it from the throttle rod
Hansen01
Postby DieselLam » Wed Aug 03, 2011 8:03 pm
It was doing it before I turned the idle down. Ill drive it a little maybe it just needs to run longer. I didn't take it out and put a load on it or anything.
DieselLam
