Dodge Down,screwed up symptoms
Re: Dodge Down,screwed up symptoms
Postby PToombs » Sat Sep 01, 2012 5:34 pm
I looked at that and said "that looks ok". Then I realized that it looks like there are 2 bottoms in the bucket. What is that brown crap?
Postby ellis93 » Sat Sep 01, 2012 5:40 pm
Don't know Mr Pete,rust I guess
Postby cougar » Sun Sep 02, 2012 10:32 am
Make them pay for everything from fuel tank to injector nozzle. Any clue as to what that is in the bottom of the buckets?
01 2500 "the work truck".
cougar
Postby ellis93 » Sun Sep 02, 2012 11:21 am
Nodda clue,I'm taking every drop to them in the morning. I one guy up the road from my said he wasn't sure if they'd make good on the repair to his truck, said some in the past had issues with their fuel and couldn't make them pay for the repairs. Reckon I'll find out :(
Postby revemup15 » Tue Sep 04, 2012 8:24 pm
Any luck?
94 p-pump
revemup15
Banned
Postby ellis93 » Wed Sep 05, 2012 3:28 am
Still waiting on a phone call......
Building a pop tester right now to test my injectors with,I'm hoping that they're just stuck and my pumps fine. :?
Postby ellis93 » Wed Sep 05, 2012 9:01 am
Well.........I'll be taking this one in the azz! :shaking: :x
Postby Black93 » Wed Sep 05, 2012 10:01 am
I didn't think they would do anything about it. My brother has a superduty, he filled it up at the pilot truck stop here about a year or so ago and it was full of water. About every 25-30 miles he would have to pull over and drain it. He's always bought diesel there and they wouldn't do anything about it, $1?? wasted.
Black93
Postby ellis93 » Wed Sep 05, 2012 10:16 am
I have bought just about all my fuel there for the last 7 or 8 years and this is the first time it's happened to me,and it'll be the last time too. :evil:
Postby ellis93 » Wed Sep 05, 2012 12:12 pm
Here's the results from the pop test of the injectors.
None leaked out the nozzle,all definitely sprayed fuel. You all still think this is what's making the truck run this way,I know the pressure being off would make it run like crap, but the hard starts and the fuel creeping out the exhaust housing now?
Postby KTA » Wed Sep 05, 2012 3:19 pm
The issue with pressure isn't that big a deal the main thing is that they chatter when they spray, if they just spray they need work. They should distinctively make a rapid chatter sound when they pop off. it should look like a cloud of fuel more so than a spray.
Postby ellis93 » Wed Sep 05, 2012 5:34 pm
Well how do I fix that cause I'm seeing 7 streams of fuel from all but one.
Thank you VERY much for this help
Postby JimmieD » Wed Sep 05, 2012 9:43 pm
1967 Dodge D-100 Town Wagon - CPL 858 4BT, HTT Stage II/H1C 16cm/56cm turbo, '93 CTD I/C, 32K spring, minor fuel tweaks, milled head, NV4500, 1 ton springs, '72 D-200 Frt. axle w/ Air Lift bags, 4.10 Dana 60HD, F/R swaybars, Tom Woods shaft.
'90 W-350 gasser...
JimmieD
Postby ellis93 » Thu Sep 06, 2012 4:46 am
JimmieD wrote:If'n it was me:
http://courts.ms.gov/trialcourts/justic ... court.html
Other general info:
http://articles.directorym.com/Small_Cl ... sippi.html
I won't go thru all of that,I find word of mouth is deadly 8)
Postby ellis93 » Thu Sep 06, 2012 9:01 am
