whats the deal???
Postby Greenleaf » Thu Feb 01, 2007 3:55 am
Give us the pump no's. I will look them over. The governor could be a bit different. You don't need an AFC to operate the pump. Some don't have one. It's an automotive application. It you mean the afc casting is there, and your only missing the diaphragm, then yes the rubber diaphragm will be the same.
Greenleaf
tech specialist/mod
Postby 92 D/UNIT » Thu Feb 01, 2007 8:50 am
yes this pump does not have any afc provisions. ill get some #s. are the all the fuel lines going to be the same?
Brian 92 D 250 250K, A518, pump mods, BHAF, 4X15s, 4" turbo back dual exh, 3200 spring, HTB2 62/12.
SOLD 92 w250 ex cab, 5 spd, 3.54, 320,000, WH1E 14, Fuel pin, pods,shortened 4200 gs, Bhaf, 4" turbo back
388/886
92 D/UNIT
Postby Greenleaf » Thu Feb 01, 2007 9:53 am
Most likely. However, the internals can differ. The head size/gov function etc.etc. can and will differ.
I'll look it up. I need the Bosch and/or the Cummins pump part number.
Greenleaf
tech specialist/mod
Postby sdstriper » Thu Feb 01, 2007 9:55 am
You mean the fuel delivery valves?
I'll take a stab and say the hyd. head will be smaller, probably 10mm and the gov' assy is probably a little different. Just a guess though. I am interested to see what you have and if you can make it work.
sdstriper
Postby PToombs » Thu Feb 01, 2007 4:49 pm
Most industrials have no AFC. It should work, but I would get the numbers to GL and let him check it.
Postby 92 D/UNIT » Thu Feb 01, 2007 7:21 pm
ok guys today i had some time to work on my truck today, so i removed the 354 gov and put the 366 in also checked(tightened) the fuel lines, retarded the timing a bit from where it was(to get to the allen) and the problem seemed to go away. feels like the power is down a little but its running good, thinking that it was the gov spring after all, dont know why it took 2 months to start acting like it did :?:
well at least now i have a pump kit if it does go T/U
i have to go out to where the engine is tomorrow to get some parts of it for a friend and ill get cummins and pump #s.
THANKS
388/886
92 D/UNIT
Postby 92 D/UNIT » Fri Feb 02, 2007 5:33 pm
engine #s
eng ser # 44366704
inj. p/n# 3909476
152hp@ 2500
fuel rate 66.7 mm 3/stroke
cpl 0938
pump #s
0 460 426 866
R 159-16
011 94351191
388/886
92 D/UNIT
Postby sdstriper » Fri Feb 02, 2007 5:37 pm
I would want Scott's opinion on this but i think your in luck on the pump. It fits the criteria of a "make from" pump from what info I have.
sdstriper
Postby 92 D/UNIT » Fri Feb 02, 2007 5:42 pm
sdstriper wrote:I would want Scott's opinion on this but i think your in luck on the pump. It fits the criteria of a "make from" pump from what info I have.
what does make from mean?
388/886
92 D/UNIT
Postby sdstriper » Sat Feb 03, 2007 2:59 am
Hope I can explain this and someone corrects me if I'm wrong or leave something off. The pumps are built and sold unit specific for engine CPL numbers, when they have the same internals they can be made to work for a different engine CPL. In the book there is a term "make from", you xxx out one number and reclassify the pump with the new numbers. This pump happens to have the right numbers for you to use I think. Sounds like you'll have to use the AFC components but the guts should be good, the gov' would be one thing in question though. From what I read if the first seven digits are the same you can use the pump as a "make from" pump. Same use different application etc.
0-Denotes complete project
4
6-Product Class Dist. Pump
0
4-Identifier for VE Inj. Pump
2-plunger dia.
6-number of cyl.
866- application number
sdstriper
Postby bgilbert » Sat Feb 03, 2007 11:18 am
Well c'mon Greenleaf!! What's the deal on that pump? Sounds like a winner the way sdstriper described it. It would be cool if you could swap on an afc housing/top cover and your 366 gov spring, then you'd have a useable VE.
92, does that industrial 5.9 have an air to water aftercooler on top it or is it non-intercooled? Selling any parts :twisted: ?
Bill Gilbert
bgilbert
Postby 92 D/UNIT » Sat Feb 03, 2007 11:22 am
non intercooled bgilbert,yes some parts are for sale what are you needing?
388/886
92 D/UNIT
Postby bgilbert » Sat Feb 03, 2007 11:50 am
Air to water aftercooler.
Bill Gilbert
bgilbert
Postby 92 D/UNIT » Sat Feb 03, 2007 7:08 pm
Scott must have a life unlike some of us, im always on the computer jumping around five different sites and ebay :roll:
388/886
92 D/UNIT
Postby PToombs » Sun Feb 04, 2007 8:04 am
92 D/UNIT wrote:Scott must have a life unlike some of us, im always on the computer jumping around five different sites and ebay :roll:
No he doesn't! :lol:
