Swaggs wrote:Do you think that the idling high, and the rpms hanging a little is from the shut off plunger? or is it another problem?
How far did you turn the fuel screw in? When you turn the fuel screw in, it will increase the idle, so you'll need to back the idle screw out to get it right again. RPM's hanging sounds like your on the verge of runaway. Might want to back the fuel screw out a little bit.
