Where's all the 5.9 air to water aftercoolers??
Postby bgilbert » Sun Feb 25, 2007 11:33 pm
:evil: You guys start your own thread :P . Or get me the stock 5.9 air to water aftercooler, then you can talk about whatever you want on this thread!!
You disbelievers seem to be missing the part that Mr. KTA made 600++HP with one of these school bus parts.
Finders fee for someone that can get me a cooler but most importantly the matching injection lines. I'd buy a new cooler from Cummins if I could get my hands on the lines.
Bill Gilbert
bgilbert
Postby 90firstgen » Mon Feb 26, 2007 12:12 am
bgilbert wrote:I'd buy a new cooler from Cummins if I could get my hands on the lines.
Me too. So if anyone comes across any then get TWO sets! Of course bgilbert gets dibs on the first ones
1990 2x4, 3/4 ton, Getrag, Cummins N/I
3200 Spring
Full Fuel Screw maxed (+/- 4 turns)
Injector rebuild with bigger nozzles
1/8" Timing bump
Airflo Intake
HTT 56mm Compressor
14cm Wastegated Housing
Stan's 4"
90firstgen
Postby Fnschlaud4620 » Mon Feb 26, 2007 7:22 am
Sorry about that Bill, It does not take too much to get me sidetracked.
I have been looking though, there is a guy in west Texas who says if you cant find the lines, if your carefull and straighten out the lines you have you can rebend them around the cooler, you can make the factory lines work, he said that it is tight and he would send me a picture, he also said that he thought a cooler from a 4bt would possiably go in between the factory lines as is, but it is a little smaller in size. and would probably cool a little less.
have you looked at aftermarket coolers on Ebay? there are a few on there for less than 200.00 dollars you would not have to buy lines and you could mount it in your fenderwell, leave your air/air in the front then just run the pipe into the water/air then into the engine.
just a few thoughts
Fnschlaud4620
http://cgi.ebay.com/ebaymotors/Liquid-Water-to-Air-Racing-Intercooler-10-x9-x4-5-NEW_W0QQcmdZViewItemQQcategoryZ33742QQihZ015QQitemZ250086946417QQrdZ1
Fnschlaud4620
Postby JLeonard » Mon Feb 26, 2007 7:36 am
I just received mine friday afternoon. Cost me $100 plus $40 to ship it.
It is in excellent condition...and the fuel lines are brandy newy! They still have the plastic protective caps on them!
I will just need gaskets and I'll have to make a 90 deg elbow for the intake. (the marine turbo bolts to the rear of the exhaust manifold).
Not braggin'.....just saying they are out there. Located mine on the 4bt Yahoo forum.
Jay
91 D250 w/modified Cummins, 89 D250 donor (future boat engine)
JLeonard
Postby bgilbert » Tue Feb 27, 2007 9:57 pm
JLeonard wrote:I just received mine friday afternoon. Cost me $100 plus $40 to ship it.
Jay
Trade ya a Freightliner intake horn :lol: :lol: :lol: !!
Bill Gilbert
bgilbert
Postby 2stroke » Wed Feb 28, 2007 11:40 am
Jay
can u show us some pics please?
91 non I/C w-350 SRW
2stroke
Postby JLeonard » Thu Mar 01, 2007 4:58 am
I'll take some pics tonight
JLeonard
Postby seeker1056 » Sat Mar 10, 2007 11:02 am
Hmmmm
I am and have been there n done that....
My truck runs a air/water intercooler, between the twins, and an air/air aftercooler.
I suspect I am the very first to run dual intercoolers in our applications, meaning trucks.
I can tell you that with the system i have installed, the air temps are almost ambient at the intake.
That equates mathematically, to about 60hp over anything currently in operation.
My egts are only 1100 under full power no matter how hard i run it so far.
Time will tell when i get this thing really runniing
seeker1056
Postby Begle1 » Sat Mar 10, 2007 9:54 pm
Seeker, you are a minor prophet of the Church of Torque.
But only if you have pictures. :twisted:
Postby bgilbert » Sat Mar 10, 2007 10:19 pm
Are you using a stock 5.9 Cummins water jacket aftercooler or a gasser type remote air/water aftercooler? I hope you're not simply using engine coolant for cooling of the air if it's a stock 5.9 cooler.
bgilbert
Postby seeker1056 » Sun Mar 11, 2007 5:46 am
Yes - I do have pics, and no I am not usin the engine coolant.
The water/air intercooler has its own self contained cooling system mounted in the box of the truck.
And yes at the moment I may be the minor torque guy, but I am strivin to be the first one over 700hp if all works out.
"WITH A LITTLE HELP FROM MY FRIENDS" AS THE BIT-LLES USED TO SING
The only thing holdin me back is, like many of you, time n money.
;O)
seeker1056
Postby 90firstgen » Sun Mar 11, 2007 1:59 pm
seeker1056 wrote:Yes - I do have pics
3200 Spring
1/8" Timing bump
Airflo Intake
HTT 56mm Compressor
Stan's 4"
90firstgen
Postby seeker1056 » Sun Mar 11, 2007 3:15 pm
dont know how to post pix here
However my pix are online in my garage over at Dodge Cummins Diesel forum under the same name I use here.
I would post the link too if I knew how.
seeker1056
Postby KTA » Sun Mar 11, 2007 4:58 pm
I used to run the boost through an air to air then a watter to air cooler on the pull truck. I know just use one big water to air and intake temps are around 120deg from 700deg. On old yellow my intake temps run about 200 or so. Good luck with the 700rwhp, that would maybe get me motivated to get mine on the dyno again. :twisted:
Postby PToombs » Sun Mar 11, 2007 5:40 pm
Seeker, just copy, then paste the address from the header on the CF into your post here. It takes some practice, I'm just learnin' too!
