89 power steering pump
Postby jdr789 » Thu Aug 04, 2011 4:01 pm
Hello every one, i need to change my power steering pump. to press the coupler with the bearing on it , do you just stand the pump vertically and press the coupler on? or will that push all of the pump inards out the bottom? thank you for your help, jerry.
jdr789
Re: 89 power steering pump
Postby jdr789 » Fri Aug 05, 2011 4:07 pm
any one have an idea of how to do this? i am broke down, have to drive this truck to get to work. any help is greatly appreciated . thank you, jerry.
jdr789
Postby collegekid » Fri Aug 05, 2011 4:31 pm
looks like you just press is on, but don't hold me to that, do some google searches for replacement of the pump
collegekid
Postby jdr789 » Fri Aug 05, 2011 5:52 pm
thank you for the reply collegekid. i have worn my old fingers to the bone on the net trying to find out, without much luck. it looks like i may have to use 3/8" threaded rod to pull the coupler onto the pump shaft.
jdr789
Postby Richie O » Fri Aug 05, 2011 7:49 pm
Never done one. Good luck.
Postby ellis93 » Fri Aug 05, 2011 8:17 pm
You can rent a tool that will work from autozone or oreilly. It looks like this.
http://www.amazon.com/gp/aw/d/B0002SRF8 ... 42-4107864
Postby jdr789 » Fri Aug 05, 2011 9:22 pm
thank you very much ellis93, that is what i thought i would need to do. i will get that tool tomorrow. thank you every one for your help, jerry.
jdr789
Postby Greenleaf » Tue Aug 09, 2011 8:46 am
That tool looks like the one for the newer trucks.
The old school engine is different. You go pressing anything onto a power steering pump shaft, you won't be using that pump.
The gear is pulled into place with a long/ grade eight stud and hard nut.
Greenleaf
tech specialist/mod
Postby ellis93 » Tue Aug 09, 2011 10:35 am
That's how the tool works. You screw it into the shaft, 3/8thsX16 threads on the end of the tool, then use the nut and bearing assembly to push the pulley/drive onto the shaft. Image
