bad starting smoke
bad starting smoke
Postby 91bluecummins » Mon Dec 05, 2011 6:53 pm
i got a 90 non intercooled truck that ive been working on and the guy i bought it from said the injection pump was bad on it so i got a rebuilt one from acme diesel. When i put it on we started it and it run rough and smoked gray so we bumped the timing. It was right on the mark like the old ip was then we bumped it up 1/8 and it run smooth and little smoke. SO now ive been driving it a little and every time i start it runs kinda rough and whiteish-gray smokes for about 10 mins. And when you give it throttle it makes more and more smoke, then when it runs for a while it clears up. I can hear the grid heater and im getting power to it and the wire to the ksb is hot when started is it supposed to be cause i know that it is suppose the be no power when it kicks on. ive unplugged it and i cant here any diffrence in the motor. Should i try to advance the timing a little more cause i know all pump timing marks are the same. I think it might be off or am i missing something else i should check.
thanks
92 cummins W250 extenged cab (The Goat) project truck
90 cummins W350 single cab dually flat bed 5 speed, he351ve 62mm
1959 chevy Apache 4bt cummins 4 speed
91bluecummins
Re: bad starting smoke
Postby 91bluecummins » Thu Dec 08, 2011 7:23 pm
or i might just have an injector stuck well pull them out and check them
91bluecummins
Postby mike8061 » Fri Dec 09, 2011 11:20 am
Some one correct me if im wrong
I thought I read that the non i/c's KSB were bacwards to the i/c's
No power for cold start and then power when warm?
92/93 W250 Ext. Cab. LP lift pump, 3200 spring, fuel screw maxed, pin almost ground through, 6" lift, flat bed, 35x12.5, big bumper
93 ext cab parted
92 reg cab parted
1967 C50 swapping in spare 5.9 auto and 205. 8.10 low in rearend. should pull somthin
mike8061
Postby dazedandconfused » Fri Dec 09, 2011 2:03 pm
I think it may be injectors. I know my 93 is the same way but it also has 427,xxx miles on stock injectors.
Postby 91bluecummins » Fri Dec 09, 2011 2:35 pm
well i got my injectors out and took them to get them checked and they said one of them was stopped up a little and i think that was my problem im intalling them back in tonight well see if that was what it was
91bluecummins
Postby 91bluecummins » Sat Dec 10, 2011 6:46 am
well i got my injetors back in and it doent do it as bad, but is there any thing esle i should do bump my timing more or what. Are nonintercooled trucks colder natured than int. trucks cause my other truck does fine
91bluecummins
Postby dazedandconfused » Sat Dec 10, 2011 10:26 am
This is mine starting up this morning.
Postby Hansen01 » Sat Dec 10, 2011 10:54 am
no offense, but that was kind of a slow start for 22 degrees,lol
i have my pump advanced an 1/8in maybe a little more and before i got my head and injectors redone, it would smoke like/or worse than yours dazed, now that i got my head and injectors redone i have almost no haze at an idle
Under construction...
Hansen01
Postby 91bluecummins » Sat Dec 10, 2011 11:01 am
will the timing being advanced make i smoke whitish gray
91bluecummins
Postby dazedandconfused » Sat Dec 10, 2011 12:35 pm
Mine also has 427,xxx miles on all stock parts except for lift pump on the motor. Sometimes she will fire just fine and fast and others it will start like that. Im still on the factory headgasket according to all the records I have.
Postby Hansen01 » Sat Dec 10, 2011 12:45 pm
ok, lol that makes a little more sense on why it started a little slow :)
Hansen01
Postby bill-d-c » Sat Dec 10, 2011 6:16 pm
Didn't sound like the battery spun it all that fast either. I put a new 1150CCA battery in mine a couple months ago and it made a big difference in cold starts.
Bill
bill-d-c
Postby dazedandconfused » Sat Dec 10, 2011 6:26 pm
It's got a brand new 1100CCA battery in it. My starter has been giving me fits and I have to beat on it sometimes to get it to start.
Postby Diesel » Sat Dec 10, 2011 10:06 pm
Dazed you got a cool truck. Hey it started twenty times faster than my buddies 6.5 Chevy starts in 65 degree weather. I think you should consider getting the starter rebuild kit just to get her spinning up faster.
1991.5 D250 Intercooled A518
Diesel
Postby 91bluecummins » Fri Dec 16, 2011 7:33 am
well i bumped my timing more and it think it fixed it
91bluecummins
