second oil sending unit location?
Postby kenmartin » Tue Jan 03, 2012 10:40 am
does anyone know of a second location to mount another sending unit?
1990 , 80 over sticks, new head with 80 pound springs, and 4" downpipe, waiting for pullitbroke to help it be what it can be!
kenmartin
Re: second oil sending unit location?
Postby CumminsPower59 » Tue Jan 03, 2012 10:59 am
Would the plugged port on the top of the oil fliter housing work?
Postby Tacoclaw » Tue Jan 03, 2012 11:15 am
Yeah, you can either "T" into the factory port or, of you don't plan on running twins, use the other port on the filter housing.
Postby kenmartin » Tue Jan 03, 2012 1:27 pm
thanks guys, ended up teeing it, the electric pickup pump runs off the oil pressure sort of a slick setup the hummer has, it now runs but still dies ten seconds after running, and starts very hard like it still isnt getting fuel, but it is! it is getting a steady volt to the fuel shutoff, doesnt change voltage! any ideas?
kenmartin
Postby ahale2772 » Tue Jan 03, 2012 1:56 pm
I would not t it if i were you. better to tap into the second one then telling the turbo that it can only have half of its lube supply. IMO
Postby Tacoclaw » Tue Jan 03, 2012 4:09 pm
I think he means he T'd out of the sender hole, Alex. :lol:
What pressure does the electric pump on that Hummer put out? Is there a chance that it's sucking the filter dry before oil pressure comes up and kicks the pump on? Even a little air is bad, so the vane pump on the VE may be pulling a vacuum in the lines after the LP. A tiny air leak there would probably not show itself once the LP gets power and kicks on, filling them with fuel again.
Postby bmoeller » Tue Jan 03, 2012 5:56 pm
ahale2772 wrote: ............then telling the turbo that it can only have half of its lube supply. IMO
Huh? :roll: It won't affect the turbo oil supply unless the sender blows. Has no where to go. Dead ends at the sender.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby bmoeller » Tue Jan 03, 2012 6:04 pm
I would run that pressure switch through the shut down solenoid circuit, with a manually operated spring loaded over-ride switch. That way, it will kill the engine, and not starve the fuel injection pump when the lift pump shuts off. Just start the engine normally. All you'll need to do, is hold the switch at start up, then let go when it starts. Lose oil pressure, engine dies (unless you hit the over-ride). The over-ride will also allow you to get to a safe spot on the shoulder (or off the street).
bmoeller
Postby ahale2772 » Thu Jan 05, 2012 8:20 am
my bad, Ive been off my game lately. i thought we were talking about t-ing for twins. but IDK why i thought that because there is no mention of twins.
Levi, you have been promoted to "oficaial corrector of AHale's BS'
Postby Tacoclaw » Thu Jan 05, 2012 11:32 am
Oh man, I better put in my two weeks at my current job then. :P
Postby PToombs » Sun Jan 08, 2012 8:59 am
Why do you think Richie needed time off? He had all of us jokers to babysit. :mrgreen:
