Your MPG
Your MPG
Postby dazedandconfused » Wed Jan 11, 2012 4:08 pm
Searched but didn't see a thread on this. I'm interested to see what everyone is getting mileage wise.
Truck setup
Stock engine, 518 auto, 3.55 gears and 265/70/16 I've been averaging 23mpg usually running 75mph to and from work. That's 60 miles of interstate and 6 miles back roads a day.
Re: Your MPG
Postby oldestof11 » Wed Jan 11, 2012 4:21 pm
Currently nothing.... Cause I haven't been driving it. The Accord gets 31 mixed. 8)
Best was 23.x going to and from SOP. 4x4 Reg cab, 5spd, 33x12.5x16.5 tires. Winter fuel is around 17-18 with 15 mins of idling every morning.
Re: Your MPG
Postby cmann250 » Wed Jan 11, 2012 5:04 pm
I found a fuel economy thread that KTA started years ago (2007).
Anyways in the truck in my sig I got 20.8 once, I can regularly get 18. I do use a splash of Power Service in most tanks if that amounts to anything. It weighs 5300 with me and a stocked tool box in it.
Andy, what does your rig weigh? Can't be much...
Also i got my truck back together, thanks 8)
Re: Your MPG
Postby dazedandconfused » Wed Jan 11, 2012 5:43 pm
Hey good to hear and no problem Caleb. I have no idea what mine weighs. I'm gonna guess around 5,000 with my big ass in it.
Re: Your MPG
Postby cmann250 » Wed Jan 11, 2012 5:51 pm
Hmmm, I would have guessed under 5k. Maybe that 8 lug chassis is heavier than I thought
Re: Your MPG
Postby dazedandconfused » Wed Jan 11, 2012 6:00 pm
It may be lighter I don't know. It's all halfton except D70 and a few pieces I changed in the front but that was only 10 pounds different.
Re: Your MPG
Postby 142autox » Wed Jan 11, 2012 6:09 pm
I'm not a very good test subject since I just got the truck a few months ago. I promptly did some pump tuning, rotated fuel pin, star wheel down 1.5 turns, full throttle screw backed out with the linkage relocated, full power screw turned in to the collar, and a fair amount of irresponsible driving.
Driving on mostly country roads with only a few miles between stop signs and very little highway driving I only got 13 mpg.
I am a little disappointed. I do have an injector knocking a bit which I'm sure isn't helping, nor did my driving style but I don't think my random hole shots took away the extra 5mpg that I feel I'm missing. It never smokes, NEVER, so I know I'm not wasting fuel there. I'll try to be more responsible on this tank to see what it does and report back.
93 W350 dually, A518. DDP stage 1 injectors, and typical pump adjustments.
142autox
Re: Your MPG
Postby Hansen01 » Wed Jan 11, 2012 6:23 pm
i once got 23 straight interstate
another tank i got 21.5 going to Marks house hitting every stoplight possible it seemed like.
4:11's power screw in till almost runaway everything else turned down, and a 6 speed
going on a 4 mile trip to school running winter fuel i get between 6 and 8 :oops: thats with close to an hour of idling.some at my house, some while doing chores, and some while at school
Under construction...
Hansen01
Re: Your MPG
Postby BC847 » Wed Jan 11, 2012 6:34 pm
I recently made a trip to the beach, drove around a little there, and came most of the way home on a tank. I can't remember how many miles. It was well over 350 IIRC. With driving it responsibly (75ish% highway @ 60 ~ 70mph, the balance around 35mph), It seems I got around 18mpg.
- 6750ish lbs (Wife, beach tac & fuel) '93 W250 CC, A518, 33" all-terrain radials.
- BrHAF, two spinny-things, BHIC, stock/OEM 12mm IP with a stiffer spring, big squirters, BHEP, different bump-stick & springs, one soup-pot, sheet aluminum, rivets 'n stuff. Hands have been layed on the head. An expensive TC and home-built trans. Most is set-up to function as the MFR intended. Some, maybe not so much.
Re: Your MPG
Postby ellis93 » Wed Jan 11, 2012 6:58 pm
Mine gets an average of 19 if ran at 70,only speed I know it seems :roll: . Best I've ever got was running 55 on some back roads with almost no stops, that gave me 21.
In work mode she get 12 to 14,depending on weight and stop and go.
Re: Your MPG
Postby CumminsPower59 » Thu Jan 12, 2012 5:44 am
I average about 18 or so, depending on where I go, most of it is two lane highways, I have hit 19.96 on a long interstate trip, keeping the spped about 65mph and the boost under 4psi. Truck scales out about 6900lbs how it sits right now...
Re: Your MPG
Postby bill-d-c » Thu Jan 12, 2012 10:24 am
92 ClubCab 4X4 with 518 auto and 3:54 gears. Gets between 20 and 21MPG. Bone stock drivetrain.
bill-d-c
Re: Your MPG
Postby 1990 » Thu Jan 12, 2012 5:32 pm
Last winter. Mostly highway, but stop and go doesn't change it.
Haven't checked the mileage on it converted yet.
2012 Subaru WRX TP Stage 1 DD
Re: Your MPG
Postby 1STGENFARMBOY » Fri Jan 13, 2012 10:24 pm
The best is 18.5 with 33x12.5x16.5, and worst is in the 12-14 range with a 4,500lb truck camper in it.
Dar
Re: Your MPG
Postby Tsbourne09 » Sat Jan 14, 2012 2:44 am
I average 14ish... Lots of fuel no afc and lead foot...
Not On Yet: 60#VS
Tsbourne09
