a/c compressor
a/c compressor
Postby remi » Mon Jan 23, 2012 6:51 pm
has anyone though of using the a/c compressor as a on board air unit if so what all needs to be done to map it work
1992 w250, a518, fuel screw borderline runaway, denny t stage 2 fuel pin, cai,4 turbo back straight pipe to 5inch stack, 4 inch lift, 3 and 1 boost, egt, tranny temp,
remi
Re: a/c compressor
Postby cmann250 » Tue Jan 24, 2012 5:24 am
York compressors seem to be the best way to go. It's the piston style pump that makes them desireable. They came on late 70's Fords
Re: a/c compressor
Postby remi » Tue Jan 24, 2012 7:47 pm
how would i run that setup
remi
Re: a/c compressor
Postby remi » Tue Jan 24, 2012 10:37 pm
i just want to run front rear bags and two 24 inch trumpets :)))))))
remi
Re: a/c compressor
Postby cmann250 » Wed Jan 25, 2012 5:57 am
remi wrote:how would i run that setup
The simplest way would be to ditch your A/C and put the York pump there. I'd assume you'd need a tank for it too. I don't really know alot about this stuff, I just helped a buddy make a set-up for his truck.
Re: a/c compressor
Postby ellis93 » Wed Jan 25, 2012 8:37 am
CMANN are you talking of the old compressers shaped up like a V-Twin motorcycle motor?
If you are I'd like to see someone put that in the same hole as our factory compressers :D
I don't know how long our compressers would last doing this. A working A/C system uses a lubricant that's circulated around with the freon and returned to the compresser. To make it pressure a tank you'd use the pressure side and leave the suction open to air with a filter. This would let its oil pump off in the tank and no lube for it. If you could devise a way to feed the suction side with some lube then your factory one could work fine.
FWIW the factory comps can pump 250psi and live fine 8)
Re: a/c compressor
Postby cmann250 » Wed Jan 25, 2012 10:02 am
ellis93 wrote:CMANN are you talking of the old compressers shaped up like a V-Twin motorcycle motor?
Yes sir, I am. Like I said, I'm not really into this kind of stuff. I just helped a friend do it once, so I don't really know the fine details. The alternator is in the easiest place to put the compressor. And yes you're right, it's a tight fit down there :lol:
Re: a/c compressor
Postby Gots_a_sol » Wed Jan 25, 2012 5:05 pm
I still haven't finished installing everything yet...
Super simple bracket. Just removed the original alternator top bracket and made a new one out of flat plate with some holes drilled for the compessor (not done yet in this pic)
-Joe
Gots_a_sol
Re: a/c compressor
Postby PToombs » Sun Jan 29, 2012 2:38 pm
Ellis, the York compressor is a single cylinder unit with a square body. It is/was used in big trucks and fords like mentioned. I have one here I was going to put on my truck and then went electric instead. Someplace I have a link to a jeep site that tells how to prep it for compressor use. Seems like you have to drill a drain hole for the oil and plug another one. I can't remember exactly. I thought it had to be upright for correct lubrication but I could be wrong. I guess got a sol will let us know. ;)
Re: a/c compressor
Postby Gots_a_sol » Sun Jan 29, 2012 3:03 pm
Standing upright is preferred but it will work on its side as well, just might consume a little more oil this way. http://www.onboardair.com/ says as long as the suction side is on top you are ok. I have a coalescing filter within a foot of the compressor to help with that.
I actually worked on getting some of the plumbing done yesterday. I wish I had ordered 90 degree fittings for the compressor and coalescing filter to clean it up a bit, oh well.
I put the tank where the spare tire would be since it won't fit under my truck any more
-Joe
Gots_a_sol
Re: a/c compressor
Postby oldestof11 » Sun Jan 29, 2012 4:39 pm
Intercooled compressors can be taken apart, oil added to the front gear housing, taping said holes for npt pipe plugs to hold the oil, and adding an air tank. Look it up on Pirate 4x4. I think the model we have is a Sandenson or something like that.
Re: a/c compressor
Postby Gots_a_sol » Fri Feb 03, 2012 8:59 pm
I got my system up and running today (save for wiring)
One air coupler can be seen on the core support next to the over flow bottle. I'll have another at the back of the truck.
It took less than 5 mins to accomplish this with a 12.5 gallon tank from completely empty at idle.
-Joe
Gots_a_sol
Re: a/c compressor
Postby PToombs » Sun Feb 05, 2012 6:45 pm
Joe, what are you running the belt off of? I see it's a Vee belt, and the idler.
Re: a/c compressor
Postby Gots_a_sol » Sun Feb 05, 2012 6:57 pm
An new alternator pulley that has serp belt and v-belt drives. I got it from http://www.onboardair.com
-Joe
Gots_a_sol
Re: a/c compressor
Postby cmann250 » Mon Feb 06, 2012 5:11 am
Gots_a_sol wrote:An new alternator pulley that has serp belt and v-belt drives.
Ahhh I see, that's the part I never could figure out. Thanks for showing that
