injector time
injector time
Postby ellis93 » Wed Feb 08, 2012 6:32 am
So I've been hearing some ticking under the hood for quit awhile and I'm figuring on it being an injector.
I've done some looking around and found,thru a another shop I use,reman injectors for 30 a piece or they'll clean,test,set pressures on my injectors for 25 a piece.
Sounds like a good deal if I want my stockers in good shape. What yall think, price fare or is that super low and cause for concern.
Re: injector time
Postby tampabayBill » Wed Feb 08, 2012 7:29 am
Sounds like a good deal. Ask around and see what their rep. is also its time to step up to some DDP stage 2 nozzles you would really like the results.
Twins coming soon!
tampabayBill
Re: injector time
Postby ellis93 » Wed Feb 08, 2012 11:09 am
Yeah,,,I had thought of that too. Rep is no problem. I've delt with them in the past on my pump and misc.parts for other cutomers vehicles.
By the time I bought the nozzles I might as well just buy they're whole injector. Seems it be about the same money.
Re: injector time
Postby u2slow » Wed Feb 08, 2012 7:22 pm
I guess I was spoiled having a non-IC truck first, with the big stock injectors - so I felt I had to get to that level at a minimum on my '93. I put in some used 5x.012's I got used. First impression... lots more fun! :mrgreen:
93 W250 Club 6BTA/5spd/3.54/Dana80/~3"lift/2gen leafs/3gen wheels/HX35/5x.012s
90 D250 6BT/5spd/3.54PwrLok
84 Ramcharger [Project} D250 6BT/5spd/3.07
... various other 75-05 mopar truck products
u2slow
Re: injector time
Postby Tsbourne09 » Wed Feb 08, 2012 10:27 pm
Just ordered some 7x.014 with added .015 tip enlargement injectors from contagious diesel!! Woot woot! Tons of fuel!!
Not On Yet: 60#VS
Tsbourne09
Re: injector time
Postby ellis93 » Thu Feb 09, 2012 6:13 am
Getting a quote today on 5x12 nozzles. Guy told me that he thought if my injectors were not in to bad of shape then the price would be 50$ an injector to build w/ nozzles. He's suppose to be getting me a hard figure today
Re: injector time
Postby ellis93 » Mon Feb 13, 2012 12:06 pm
People won't call me back, really pisses me off :x makes me really want to pay them money :/
Re: injector time
Postby 142autox » Mon Feb 13, 2012 5:59 pm
Then do what I did. I put the DDP stage 1 injectors in mine but you may want to go bigger. I called them and told them what my intentions were with the truck and they recommended me an injector to fit my needs. I called other companies before ordering and they either A. didn't answer or return my call or B. didn't know a thing about their injectors, # of holes, size of holes, spray pattern, pop pressure, etc. All they would tell me is "ther 50 horse jectors". So I went with the ones that attempted to know anything about their product and answered their phone.
Be prepared for disappointment on the knock going away though. I had high hopes for my cold knock to go away but it didn't.
93 W350 dually, A518. DDP stage 1 injectors, and typical pump adjustments.
142autox
Re: injector time
Postby ellis93 » Mon Feb 13, 2012 8:12 pm
Dudes got family troubles or so the shop tells me. So I reckon I'll wait on him :?
This is no cold fuel knock, higher rpm cold or hot. Sound like rocker slap,like out of adjustment.
