Tsbourne09 wrote:I use a raptor 150 and it is great! Easy to hook up also.
Tacoclaw wrote:If you want to stay mechanical you can run the P-pump LP with a boost-reference reguator, but after that mechanical stuff gets pricey. It should be able to support 400hp fairly easily.
:edit: From what I've gathered in the last few minutes, the P-pump LP runs out of steam at around 500 horse on a P-pump truck.
revemup15 wrote:are you refering to a stock LP on the ppump trucks?
oldestof11 wrote:Tacoclaw wrote:If you want to stay mechanical you can run the P-pump LP with a boost-reference reguator, but after that mechanical stuff gets pricey. It should be able to support 400hp fairly easily.
Upgrade the lines to 1/2" and 600 is the top of the limit.
