Aftermarket lift pumps
Postby revemup15 » Wed Feb 08, 2012 6:54 pm
Hey guys just curious what lift pumps y'all are using.... my plan is around 400-450hp.... I was going to go with a low pressure piston pump on eBay but I just read that they can only take around 300hp... any opinions would be appericated also.... thanks in advance
94 p-pump
revemup15
Banned
Re: Aftermarket lift pumps
Postby Tsbourne09 » Thu Feb 09, 2012 1:55 pm
I use a raptor 150 and it is great! Easy to hook up also.
Not On Yet: 60#VS
Tsbourne09
Postby revemup15 » Thu Feb 09, 2012 2:05 pm
Normally how much HP can a raptor 150 support
94 p-pump
revemup15
Banned
Postby Tacoclaw » Thu Feb 09, 2012 2:16 pm
If you want to stay mechanical you can run the P-pump LP with a boost-reference reguator, but after that mechanical stuff gets pricey. It should be able to support 400hp fairly easily.
:edit: From what I've gathered in the last few minutes, the P-pump LP runs out of steam at around 500 horse on a P-pump truck.
Postby revemup15 » Thu Feb 09, 2012 2:33 pm
Thanks taco claw for the info.... are you refering to a stock LP on the ppump trucks?
94 p-pump
revemup15
Banned
Postby PToombs » Thu Feb 09, 2012 5:53 pm
I make 350hp on my LPPP.
Postby Hansen01 » Thu Feb 09, 2012 8:10 pm
Tsbourne09 wrote:I use a raptor 150 and it is great! Easy to hook up also.
they sent me the wrong lines, but other than that it was a simple install.
oh, and if you end up going electric with new lines, be carefull of the quick attach fitting on the top of the tank, i broke the nipple it attached to on mine :x
Under construction...
Hansen01
Postby BC847 » Thu Feb 09, 2012 8:20 pm
A Walbro 392 and external regulator serves my mess alright. :)
Postby revemup15 » Thu Feb 09, 2012 8:50 pm
Keep them coming guys.... is there any that I or any other newbie :) should look out for when shopping for a LP?
94 p-pump
revemup15
Banned
Postby IowaCummins » Thu Feb 09, 2012 9:06 pm
walbro 392 with a regulator i set mine at 17psi and at 3600rpm with 7x.014s she only dropped to 16psi
IowaCummins
Postby oldestof11 » Fri Feb 10, 2012 7:42 pm
Tacoclaw wrote:If you want to stay mechanical you can run the P-pump LP with a boost-reference reguator, but after that mechanical stuff gets pricey. It should be able to support 400hp fairly easily.
Upgrade the lines to 1/2" and 600 is the top of the limit.
Postby Tacoclaw » Fri Feb 10, 2012 7:48 pm
Well crap, guess mine won't be usable on my truck after all. :grin:
Postby Tacoclaw » Fri Feb 10, 2012 8:45 pm
revemup15 wrote:are you refering to a stock LP on the ppump trucks?
I typed out a confirmation to this I thought, must have forgot to hit reply. :oops:
Yes, the factory P-pump LP is generally known around these parts as the HPLP.
Postby fatty » Sat Feb 11, 2012 2:34 am
Ron A made 1200 something horses on a piston pump, he forgot to flip the switch for the electric pump to kick in. :shock:
