just curious....
just curious....
Postby revemup15 » Sat Feb 11, 2012 8:30 pm
What's the Max HP someone can get out if a non ic truck before they would need to intercool it? Thanks
94 p-pump
revemup15
Banned
Re: just curious....
Postby Kasper Cummins » Sat Feb 11, 2012 9:18 pm
With the stock turbo or any turbo, on just fuel or on the bottle?
92 W250 club cab
Kasper Cummins
Postby revemup15 » Sat Feb 11, 2012 9:24 pm
Any Turbo and just fuel
94 p-pump
revemup15
Banned
Postby Kasper Cummins » Sat Feb 11, 2012 9:44 pm
Well an intercooler reduces EGTs. So as long as your turbo can move enough air to keep your pistons from melting you are only limited by how much fuel they flow.
I seen some where 300hp is doable with a stockish setup.
92 W250 club cab
Kasper Cummins
Postby revemup15 » Sat Feb 11, 2012 9:45 pm
So if I had a Hx40 I could hit around 400?
94 p-pump
revemup15
Banned
Postby peobryant » Sun Feb 12, 2012 1:04 am
revemup15 wrote:So if I had a Hx40 I could hit around 400?
I doubt you could hit that without an intercooler. Maybe if it was just a dyno queen it may be able to hit 400rwhp (again, I still doubt it) but for a daily driver and especially if it will be towing anything you'll need an intercooler.
Postby revemup15 » Sun Feb 12, 2012 4:00 am
Ill never do any towing hell I never will even pull a fat girl off a cheese burger
94 p-pump
revemup15
Banned
Postby ellis93 » Sun Feb 12, 2012 4:44 am
That's funny :lol:
Postby CumminsPower59 » Sun Feb 12, 2012 4:54 am
Postby oldestof11 » Sun Feb 12, 2012 7:23 am
Intercooling helps reduce the hot air being pushed out of your turbo. It helps at making the air more oxygen dense so it burns better in the cylinder. If you don't and you hit 400, a good sized cooler may help you to break 440...
Postby revemup15 » Sun Feb 12, 2012 7:50 am
Does any have a intercooler and pipes for sale?
94 p-pump
revemup15
Banned
Postby revemup15 » Mon Feb 13, 2012 12:37 pm
Is there any benefits to making a 3in crossover pipe?
94 p-pump
revemup15
Banned
Postby BILTIT » Mon Feb 13, 2012 12:46 pm
Where are you located? I have stock intercooler, piping and H1C turbo off a 91.5 available.
Derek B.
BILTIT
Postby revemup15 » Mon Feb 13, 2012 12:57 pm
How much shipped to Indiana.... don't want the Turbo.... just all the pipes boots and intercooler.... zipcode is 47424
94 p-pump
revemup15
Banned
Postby BILTIT » Mon Feb 13, 2012 3:16 pm
Probably too much, the intercooler wont be cheap to ship but i will look into it.
Derek B.
BILTIT
