Run away? 911!!
Run away? 911!!
Postby ACFarmer » Tue Mar 13, 2012 4:54 pm
I just had the top off a pump to put a throttle shaft seal in it. In the process my index mark got lost. I've had it together 3 times now. 1st time it idled about right, maybe a hair high but when you pulled the linkage it throttled down? Figured maybe it was indexed to far clockwise. Pulled apart and relocked it, this time it ran away. I tried to split the difference this 3rd time but I haven't tried it again yet. What is the deal here? Just indexed wrong? I need the truck going tonight! Any ideas???
1991 W350 single cab NV4500 in bad need of some work...
06 Dodge 3500 single cab 4x4 dually 6 speed
1997 Dodge 2500 ext. cab long bed 5 speed 4x4 with a hood stack
ACFarmer
Re: Run away? 911!!
Postby PToombs » Tue Mar 13, 2012 4:59 pm
The 1st time you had the shaft in 180* wrong. The arm was towards the fender, it needs to be towards the engine. Do it again, and don't get in a hurry. If when you start it it idles high, try to adjust it, or move the lever on the shaftcounter clockwise 1 notch. If it idles way low, or only starts with a little throttle, move the lever clockwise 1.
Re: Run away? 911!!
Postby ACFarmer » Tue Mar 13, 2012 5:25 pm
Didn't seem like I moved it enough to go 180 from the fender to the block but maybe I did. Guess ill keep trying.
ACFarmer
Re: Run away? 911!!
Postby BC847 » Tue Mar 13, 2012 6:40 pm
If it turns out to be on the verge of run-away, simply back out the main fuel-screw a little. ;)
Re: Run away? 911!!
Postby ACFarmer » Tue Mar 13, 2012 7:46 pm
I haven't turned it up any more since I took the pump apart.
ACFarmer
