Tacoclaw wrote:Just mod away on it. If you crank the pump you're going to have to upgrade your lift pump and turbo. If you upgrade your turbo you're eventually going to need studs.
Tacoclaw wrote:Justin is a liar, don't listen to him.
If you're not a quitter, you can just be happy with a VE, studs, and some o-rings if you're nervous(on the reliability front) . If you're not really comfortable with your sexual orientation, you're going to need a P-pump, too.
