bus cummins
bus cummins
Postby (92)cummins » Mon Mar 19, 2012 6:48 pm
the local junkyard in my area has some old buses with cummins and i was wondering if those motors are different in any way like if the mileage would be different or power
92 w350 srw flatbed
1985 D350 crew cab diesel conversion in progress
79 w200 power wagon
93 D350 drw 5spd getrag 4 door donor
90 D350 auto(fried) flatbed
93 D250 auto
(92)cummins
Re: bus cummins
Postby CUMMINSDODGEMAN3 » Tue Mar 20, 2012 5:25 am
different govenor springs but most of them were still just VE's, are they in like F700's?
CUMMINSDODGEMAN3
Re: bus cummins
Postby Mark Nixon » Tue Mar 20, 2012 8:28 am
A different governor spring?
They are a non-stationary engine with an AFC, so the pumps are still designed for on-road use.
Other than POSSIBLY having a different' linkage arm, they will perform and function the same as the pumps on the 1st gen Dodges.
Re: bus cummins
Postby cmann250 » Tue Mar 20, 2012 9:10 am
I'd doubt they have a differnt gov spring. I looked at BobS's post in the Parts Numbers seaction and the lowest listed is the 2800 spring that is stock in our trucks. I doubt they would put a hot rod spring in a bus :lol:
Another thing is they may have the wide aftercooled lines that open up alot of intake possibilities. I think Tacoclaw used them on his truck
Re: bus cummins
Postby (92)cummins » Tue Mar 20, 2012 10:02 am
alright i want to go there soon and i will check them out
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
Re: bus cummins
Postby CUMMINSDODGEMAN3 » Tue Mar 20, 2012 10:18 am
cmann250 wrote:I'd doubt they have a differnt gov spring. I looked at BobS's post in the Parts Numbers seaction and the lowest listed is the 2800 spring that is stock in our trucks. I doubt they would put a hot rod spring in a bus :lol:
Who said anything about a hot rod spring?
Team Green's old hauler 05 3500 CTD 4x4 6sp 8in rize industries lift, 37 Toyo M/T's, Smarty, Edge Att, AFE intake, ATS manifold Borg Warner turbo, 5in SS MBRP
90 W350 CTD SRW big pump, big turbo, lots of fuel, 47RH billet suncoast triple disc and 20's
93 D250 CTD ext cab pump work, POD's
CUMMINSDODGEMAN3
Re: bus cummins
Postby cmann250 » Tue Mar 20, 2012 10:25 am
If 2800 rpm is the lowest offered and our trucks came with that, then by default any other spring would have to be higher. I may have misunderstood what you said
Re: bus cummins
Postby Mark Nixon » Tue Mar 20, 2012 10:57 am
I'm betting they don't even have different governor springs.
An injection pump number, or engine CPL number, would take care of any of the supposition on this. :roll:
