LPPLP = WOW
LPPLP = WOW
Postby cmann250 » Wed Apr 04, 2012 6:20 pm
I installed my LPPLP and hooolllllyyyyy cow. With my fuel screw border line run away, I'd say my stock diaphram pump wasn't keeping up. On a WOT run, it kept pulling hard until I ran out of gear.
Now you guys have to hold me to it! I'm set on fuel, I have all I need. :lol: Goin after air next 8)
For anyone considering this swap, don't bend the fuel line! Cut more of the insulation ;)
Re: LPPLP = WOW
Postby Tacoclaw » Wed Apr 04, 2012 6:22 pm
cmann250 wrote:I'm set on fuel, I have all I need. :lol: Goin after air next 8)
Yeah, just like my first boost gauge, 35lb, was all that I'd ever need. :lol:
Re: LPPLP = WOW
Postby PToombs » Thu Apr 05, 2012 5:29 pm
cmann250 wrote:For anyone considering this swap, don't bend the fuel line! Cut more of the insulation ;)
Well duhhh! Does anybody read the directions for installing this? Obviously not! :roll:
Re: LPPLP = WOW
Postby BILTIT » Thu Apr 05, 2012 7:10 pm
I see reference to insulation, what insulation?
I am almost positive mine doesn't have any.
Maybe i need to look closer?
Derek B.
BILTIT
Re: LPPLP = WOW
Postby cmann250 » Fri Apr 06, 2012 4:20 am
My name for it is tappet cover insulation, but It's real name may be something else. It may be hard to tell because it's rubber on the outside with foam inside and unless your engine bay is clean enough to eat off of, it all kind of looks the same :lol:
Re: LPPLP = WOW
Postby PToombs » Sat Apr 07, 2012 6:08 pm
Tappet cover insulation is correct. It's supposed to cut down on noise from that area, and it works very well. :lol: It needs to be cut out when you put on the piston LP because the outlet line will hit it.
Re: LPPLP = WOW
Postby dpuckett » Tue Apr 10, 2012 7:30 am
So if I put the insulation back on, you're saying it will quiet my engine some?
Back on track. I had a w350 with 80hp Bully Dogs. Smoked like a coal fired freight train, but it was even out the stacks. I had the injectors sold before I installed the piston lift pump I had bought 4mo earlier. Piston pump cut the smoke to almost zero. Shoulda just returned the guy's money, lol.....
Re: LPPLP = WOW
Postby PToombs » Tue Apr 10, 2012 5:26 pm
DP, sure will. Most of the tappet noise anyways.
Re: LPPLP = WOW
Postby Dieselwrencher » Wed Apr 18, 2012 3:59 pm
Have any of you seen any over pressuring issues at higher RPM's with the piston vs the diaphram lift pumps? The piston pumps can get up to 38-40psi or more. What is the limit on the seals of the VE before it fills the crankcase with fuel?
2000 Excursion VE 24v 47RH 4x4
1976 Chevy K30 Crew Cab Short box P-pump 12v 47RH
1972 Chavy K30 P-pump 24v 47RH
1968 Corvette 5.9 47RH
Dieselwrencher
Re: LPPLP = WOW
Postby cmann250 » Wed Apr 18, 2012 4:14 pm
Dieselwrencher wrote:Have any of you seen any over pressuring issues at higher RPM's with the piston vs the diaphram lift pumps? The piston pumps can get up to 38-40psi or more. What is the limit on the seals of the VE before it fills the crankcase with fuel?
The one I have is not the one intended for P7100 trucks. The max input pressure varys depending on who you talk to. With my luck, my self imposed max is 15 PSI :;-|: I just have a 3200 spring and I don't spend hardly any time up in that RPM range any how. I'll never melt a dyno, win a pull or a race, and I'm fine with that :lol:
Re: LPPLP = WOW
Postby oldestof11 » Wed Apr 18, 2012 4:21 pm
I ran 18psi for a year on my old truck with a Walbro 392.
Re: LPPLP = WOW
Postby Dieselwrencher » Wed Apr 18, 2012 4:22 pm
Ok, I wasn't sure. I hear guys say all the time it'll be alright. :lol:
Dieselwrencher
Users browsing this forum: No registered users and 66 guests
