Now you guys have to hold me to it! I'm set on fuel, I have all I need.
For anyone considering this swap, don't bend the fuel line! Cut more of the insulation
cmann250 wrote:I'm set on fuel, I have all I need.Goin after air next
cmann250 wrote:For anyone considering this swap, don't bend the fuel line! Cut more of the insulation
Dieselwrencher wrote:Have any of you seen any over pressuring issues at higher RPM's with the piston vs the diaphram lift pumps? The piston pumps can get up to 38-40psi or more. What is the limit on the seals of the VE before it fills the crankcase with fuel?
cmann250 wrote:Dieselwrencher wrote:Have any of you seen any over pressuring issues at higher RPM's with the piston vs the diaphram lift pumps? The piston pumps can get up to 38-40psi or more. What is the limit on the seals of the VE before it fills the crankcase with fuel?
The one I have is not the one intended for P7100 trucks. The max input pressure varys depending on who you talk to. With my luck, my self imposed max is 15 PSII just have a 3200 spring and I don't spend hardly any time up in that RPM range any how. I'll never melt a dyno, win a pull or a race, and I'm fine with that
