M2 or M3 fuel pin?
M2 or M3 fuel pin?
Postby 93DodgeCummins » Tue May 08, 2012 7:25 pm
I like to play sometimes but i dont want that much bottom end smoke but i do like throttle that isn't too laggy. What do you think is the better pin? I also pull a heavy camper in the summer time and dont want much smoke. i am also installing a 3200rpm spring soon
93 Dodge W250 4X4, Custom air intake, Diamond Eye 4 inch turbo back straight pipe exhaust, HX-35W with Banks upgrades, KDP fixed, Getrag 5 speed, Isspro Tach, pyro, fuel pressure, and boost. Raptor 150, 3200 rpm spring, Power Screw in 1 turn, aftermarket fuel pin
93DodgeCummins
Re: M2 or M3 fuel pin?
Postby ellis93 » Tue May 08, 2012 7:46 pm
I tow with my m2,smokes controllable with it but i can make the truck smoke like a train if I'm wanting it too ;)
Postby thechoochlyman » Thu May 10, 2012 9:19 pm
If you look up the M&H Fuel Pin dyno runs on YouTube, the M3 actually gets the best power, IIRC.
'89 D350 - Denny T Stage II, 366 GSK, HX-35, Powerstroke IC, Power Screw 1/2 turn from runaway, 2nd gen seats, 35% tint, Sony Head Unit, 4" Exhaust, Replaced everything replaceable.
B O T T S R
thechoochlyman
Postby cougar » Sat May 12, 2012 9:00 am
ellis93 wrote:I tow with my m2,smokes controllable with it but i can make the truck smoke like a train if I'm wanting it too ;)
Me too. Tightening up the star wheel helps some.
01 2500 "the work truck".
cougar
Postby nolafishr » Tue Sep 25, 2012 2:09 pm
I went with the M4 Fuel Pin, Fuel is almost instant when you get on it, does not smoke either!
nolafishr
