Cruise control issues
Postby rustoleum93 » Sun Aug 05, 2012 9:29 am
Hello all, I'm new here.
I have a 93' LE 1 ton dually and the cruise isn't working. Anyone have the same problem?
Any ideas you can give will be greatly appreciated.
The power mirrors as are not working either.
Fuses are okay.
The Anti-Prius> 93' D350 5 speed, 4" turbo back, performance intake, just about everything possible done to the mechanics besides diving into the engine.
07' 3500, 6.7, 6 speed, Inferno Red, crew cab, dually, H&S programer and dpf delete kit, 5" turbo back dual side pipes , AEM intake.
79' Ford F250 Custom with 5.4 fuel injected V8 and 5 speed manual, still working on this one.
rustoleum93
Re: Cruise control issues
Postby cougar » Sun Aug 05, 2012 5:50 pm
Welcome new here. I have a 92 with a cruise control issue also. Mine slowly accelerates when engaged. Can you describe what it is doing or not doing? There are quite a few things to check. A better description could help narrow it down.
01 2500 "the work truck".
cougar
Postby dazedandconfused » Mon Aug 06, 2012 8:50 am
cougar wrote:Welcome new here. I have a 92 with a cruise control issue also. Mine slowly accelerates when engaged. Can you describe what it is doing or not doing? There are quite a few things to check. A better description could help narrow it down.
Like already said there are many things that cause issues. Is everything still intact? Does the horn work?
Postby ellis93 » Mon Aug 06, 2012 10:30 am
Dirty nasty buttons did that for me on mine,took them off,ran denatured alcohol thru them and fixed that.
Postby ellis93 » Mon Aug 06, 2012 10:34 am
rustoleum93 wrote:Hello all, I'm new here.
Fuses are okay.
Did you check them with a test light to make sure 12v was there,dodge is world renown for things of this nature. Andy has one common thing that likes to go as well,if the horn doesn't work then the tape(clocking spring) is bad.
Postby rustoleum93 » Mon Aug 06, 2012 3:25 pm
Hello all and thanks for the input.
The horn does work, everything works but the cruise.
I will try checking the voltage.
I suppose I had it coming...thanks, New Here.
rustoleum93
Postby cougar » Tue Aug 07, 2012 9:13 am
As said, there is the on/off and setting switches. There is also the clock spring, the brake and clutch disengage switches, the VSS, the servo, and the PCM. Lots to check. I'll check my wheel switches as soon as I get the truck back from the tranny shop. Thanks ellis93 :mrgreen:
cougar
Postby rustoleum93 » Thu Aug 09, 2012 5:42 pm
Okay, thanks for the direction, I really appreciate all the help.
rustoleum93
Postby ftexbassman » Mon Sep 03, 2012 3:20 am
I got a 92 that when ya set the cruise it takes off like ya floored the foot feed. Gets up to about 80-85 then lets off, like ya turned it off. I think its in the buttons. I just aint had a chance to tear it down and clean and inspect everything.
ftexbassman
Postby JimmieD » Wed Sep 05, 2012 9:57 pm
First thing to check on all vehicle electrical problems is the grounds. I've found ground faults to be the cause of over 50% of problems over the years. A bad ground can be weird because several circuits work fine, one doesnt. That can be due to some circuits pulling much higher amperage, so they have the power to complete circuit even with bad grounds. But a lower amperage circuit can be dead, even though it shares the same ground, because there's just not enough extra power there to overcome fault and complete ground. I usually run extra grounds between firewall & fenders, fenders and radiator support, cab & bed etc. just to be sure of continuous circuits.
1967 Dodge D-100 Town Wagon - CPL 858 4BT, HTT Stage II/H1C 16cm/56cm turbo, '93 CTD I/C, 32K spring, minor fuel tweaks, milled head, NV4500, 1 ton springs, '72 D-200 Frt. axle w/ Air Lift bags, 4.10 Dana 60HD, F/R swaybars, Tom Woods shaft.
'90 W-350 gasser...
JimmieD
