Hello all, I'm new here.
I have a 93' LE 1 ton dually and the cruise isn't working. Anyone have the same problem?
Any ideas you can give will be greatly appreciated.
The power mirrors as are not working either.
Fuses are okay.
cougar wrote:Welcome new here. I have a 92 with a cruise control issue also. Mine slowly accelerates when engaged. Can you describe what it is doing or not doing? There are quite a few things to check. A better description could help narrow it down.
rustoleum93 wrote:Hello all, I'm new here.
Fuses are okay.
