Broke my oil pressure sender
Postby Chuck Snider » Sun Sep 02, 2012 3:09 pm
Just busted my oil pressure sensor on the block.1992 W250. Will a second gen sensor be the same?
93W250 CC auto
92W250 CC NV4500
Chuck Snider
Re: Broke my oil pressure sender
Postby PToombs » Sun Sep 02, 2012 5:31 pm
Pretty sure not. Check Genos Garage, they have pics of them to make sure you get the right one. Someplace between 91 and 93 they changed them too.
Postby Bmarshall205 » Mon Sep 03, 2012 11:03 am
Should be the same. My 96 has the same as my 92 does.
Bmarshall205
Postby Chuck Snider » Tue Sep 04, 2012 3:52 pm
Well I did some research and found out that "some" 2nd gens have the same pressure sensor and some have one with a different pin-out for the wire hook-up...
93W250 CC auto
92W250 CC NV4500
Chuck Snider
Postby PToombs » Tue Sep 04, 2012 4:58 pm
Checking the Genos catalog, '90 to '93 take the same as '94 to '98, 12 valve, 2 prong connector. On the next page it says '94 to '98 2 prong connector, but it's shaped different. 1st gens and some 2nds are oval plug with round prongs, the other 2nd gen one is almost square with 2 flat prongs offset to the bottom.
The part number for the 1st gen one is 3923200. This is the number in the Genos book and it may be a Cummins part number, it looks like one.
Postby slow_90firebird » Fri Sep 07, 2012 9:17 am
Broke mine when taking out vac and power steering pump. Got new one at autozone cheap and works great...
slow_90firebird
