Serp belt install
Serp belt install
Postby stoneagemaxx » Thu Sep 06, 2012 2:05 pm
So my 91 threw the belt got a new one gates makes it and it seems a lil short returned it to napa ordered another from Oriellys. Another gates all i can seem to find ne others same prob the package says its the 83 3/4 the truck is intercooled n a/c so i checked here to get the part number cuz with all the stuff i work on and trusting auto parts stor computers for the right part i always check ahead and yes i know the routing is right also the
91 d250. 2wd std cab i/c convert 3.07 rears autometer guages htt stage 3 turbo 47rh convert 2 manualy controled od an lockup turns on fuel screw .5 on smoke screw and fuel pin rotated 3800gsk timing jumped 1 tooth retarded on pump settings for now resealed ip to come in spring he351ve and full 4 in ex hopefully injectors coolertubz for the other rig thanks Tim
stoneagemaxx
Re: Serp belt install
Postby bmoeller » Thu Sep 06, 2012 8:50 pm
The new belt is fairly snug. Takes some doing to get it on.
If the belt was thrown, vs snapped, I'd be looking at the tensioner. Could be bad.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby stoneagemaxx » Fri Sep 07, 2012 4:38 am
I was thinking the same thing the tensioner has good holding tension spins freely/no noise and is in perfect alignment w/all the pullys i checked everything multiple times about half way through it split down the centeri hate to waste a belt but thats what warranties. R for my commercial. Acct is for n knowing the GM for over 13 years goes. A long way thx for you're info
stoneagemaxx
Postby slow_90firebird » Fri Sep 07, 2012 9:13 am
It's a pita you need to get it over all the pulleys except 1 I had to use the water pump I believe because it's smooth. I could not get it on the alternator bc the outer rib is too tall. And there is barely room to release the tensioner ALL the way with a 1/2" ratchet
slow_90firebird
Postby stoneagemaxx » Fri Sep 07, 2012 10:38 am
Its on thats one tight fit the last one i insalled on the 92 dident seem that bad as far as i can remember i just loosened the alt bots and after a lil fighting got it to slip onto the wp
stoneagemaxx
Postby directinjktn1stgen » Tue Sep 18, 2012 3:30 pm
we have been replacing all the belts on diesels with these GATES-K081264HD it elimnates the that squak when u shut the motor down and also are never seen one jump off alot stronger than the regualr black belt i would try it and a new tensioner :wrench:
1992 w250 4x4 4" custom turbo back exhaust 5x.012 HVLP lift pump 3200 181/210 M3 fuel pin, gated hx35 auto important meters
Jeffery
http://i1259.photobucket.com/albums/ii5 ... af0c34.jpg
directinjktn1stgen
Postby stoneagemaxx » Tue Sep 18, 2012 7:21 pm
Thanks will have to order one for the shelf
stoneagemaxx
Postby dunes450r » Tue Sep 18, 2012 9:19 pm
directinjktn1stgen wrote:we have been replacing all the belts on diesels with these GATES-K081264HD it elimnates the that squak when u shut the motor down and also are never seen one jump off alot stronger than the regualr black belt i would try it and a new tensioner :wrench:
i also put a new pulley on my belt tensioner because the old one was getting grooved. before the pulley i had started to develop a belt squeak at idle, and i've always had a loud squeal on shut down. with the new pulley, and same old belt i don't have any squeak at idle and a very small occasional chirp on shutdown
dunes450r
Postby 12vsuburban » Sun Dec 30, 2012 3:35 am
will this HD belt work on non industrial AC trucks?
12vsuburban
Postby monoblock » Sat Jan 12, 2013 8:58 pm
Suggest you rely on Geno's Garage to get the correct part number. You need the "Fleetline" Heavy Duty bely by Gates and I believe that is the only one they sell.
monoblock
