skilletHky wrote:my 5 hole injectors run better and get better mpg than my 7 hole, but my 7 hole set is pretty large. my 5 hole set is a 5x.016 i think, ddp dose not go by hole size, and my 7's are a 7x.015.
Ram360man wrote:I dont see a need for more then just the stock injector unless you plan on getting more air. 60mm gds with powerstroke intercooler I could hit 1700 degrees. Had plenty of fuel left over to burn. 63/68 turbo dropped that down to 1400. Went to 5x14 injectors didn't notice much if any performance gain and went up to 1500 on the pyrometer.
Sutter1stgen wrote:Non intercooled trucks have way more fuel stock then the newer trucks. I believe you when you say how hot it ran. I melted my early 91' engine down with stock injectors and young foolish behavior. Now the stock injectors In The intercooled newer truck leave a little to be desired. I've been in multiple trucks where 1000 degrees is all they could hit.
Eric
Ram360man wrote:Sutter1stgen wrote:Non intercooled trucks have way more fuel stock then the newer trucks. I believe you when you say how hot it ran. I melted my early 91' engine down with stock injectors and young foolish behavior. Now the stock injectors In The intercooled newer truck leave a little to be desired. I've been in multiple trucks where 1000 degrees is all they could hit.
Eric
I know the N/IC trucks have larger injectors. Thats why both of mine are 89s.The OP has a 90 with the 4X13 injector and I just dont see a reason for more fuel. Unless he throws more air at it and a intercooler.
