Sound like a good deal?
Postby diesel davy » Fri Sep 28, 2012 12:07 pm
I found a 6 blade h x40 for sale for $300 no shaft play sound like a good deal?
diesel davy
Re: Sound like a good deal?
Postby GoldenRule » Sun Oct 07, 2012 11:48 pm
Pretty decent price for an hx40 I guess, but is that the turbo you really want for your application? What size is the turbine housing? What else are you running on your truck? What do you want to do with it? Could be a little laggy especially on the low end. Are you running stock h1c now? If so, have you tried just switching to a smaller turbine housing like a 16cm non-wastegated or a 12cm wastegated? You can do that for about 1/2 the price and it makes a big difference - especially with low end spool.
You can upgrade to 60mm compressor wheel and housing later for another $200-300 if that doesn't make you happy.
If you want the HX40, might look for a "super40" Hx35/40 hybrid. You can find an hx35 for about $250 and add the upgraded hx40 60mm 7 blade wheel and housing like this (http://baeturbosystems.com/compressorwh ... 1-2-3.aspx)
for another $200 and probably be much happier. Just my .02.
GoldenRule
Postby bmoeller » Tue Oct 09, 2012 5:43 am
I prefer the modded H1C I have, vs the PDR HX40 I had on my '97. The H1C has a HTT 60 comp wheel and non-gated 14. Spools MUCH faster. :) Super40 should be similar.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby ellis93 » Tue Oct 09, 2012 5:56 am
bmoeller wrote:I prefer the modded H1C I have, The H1C has a HTT 60 comp wheel and non-gated 14.
^^^this
Postby Philip » Tue Oct 09, 2012 2:28 pm
Keep looking. The 6 blade wheel isn't the best one offered. Find a 7 blade intake wheel model.
Postby diesel davy » Wed Oct 10, 2012 8:08 pm
I have a maxed out pump to the head Denny t stage 2 16cm housing bhaf and it's a non innercooled but egts only go up to 1200 before turbo it runs like a raped ape gets 30 pound of boost I like my pump settings just want to clean the black smoke up im looking at the 60mm upgrade also I've messed with 7.3s my whole life now messing with these cummins and let me tell you just pump mods would run circles around my old maxed out idi only other mod to do was water\meth propane or nitrous
diesel davy
